HELP - IGNITION NO WORKY??
Old Apr 3, 2007 | 03:18 AM
ratnacage's Avatar
ratnacage
Default HELP - IGNITION NO WORKY??
I've done my due diligence and searched this forum for a similar issue to no avail.
I had a Cervini C500 built for a customer of mine overseas (our local speed shop did all the work). It's a beautifully running car laying down 441 to the wheels, but I digress. It was running perfectly when I loaded it on the truck, the freaight forwarder had no issues loading (driving) it into it's container for the 20 day voyage overseas. Upon arrival it was noted the battery was dead (they should've disconnected the battery) so they pushed the car out and charged it. Now the car won't start.
Here's what it did do:
on the first attempt to start it, it huffed like it wanted to start, but ever since then it just turns over with no ignition.
The fuel pump primes
The starter turns the engine over (it's not weak either, it cranks the engine over robustly)
you can smell fuel from the exhaust (as reported to me by my customer)
...just a complete absence of any hint at ignition.
Also, the anti-theft padlock light flashes (but again, if it were an antitheft issue, the engine shouldn't even turn over, right?), but everything else seems to work (radio, AC, etc)
I sent him instructions on how to retrieve the fault codes (DTC) using the SCT tuner. I'll check that out when he reports back to me with the codes, if any.
I'm a salesman trying to help my customer, and a Mustang fanatic (see sig) so I don't think I'm completely stupid, but I've never seen anything like this on distributerless ignitions. I'm really hoping it's not the ECM. Any ideas would be greatly appreciated.
Summary:
car runs great
car gets loaded on ship
battery goes dead
battery is recharged
car won't start, but turns over, fuel pump seems to work.
Old Apr 3, 2007 | 03:41 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: HELP - IGNITION NO WORKY??
What mods does it have performance wise? Just the tuner? What about an aftermarket or dealer installed alarm?
Old Apr 3, 2007 | 03:46 AM
ratnacage's Avatar
ratnacage
ORIGINAL: PROMETHEUS PRIME
Procharger, injectors, boost-a-pump, SCT custom tune, and yes, a dealer installed alarm (but it's a Ford piece). I had him put thealarm in valet mode and it doesn't change anything. Normally, if the alarm is preventing starting the car, it won't even turn over.
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jessicarabbit
Sep 25, 2015 12:41 PM
Wombatnation
Sep 13, 2015 09:16 PM
