Weird happenings with airbag light.......
RE: Weird happenings with airbag light.......
The seat occupant classification sensor (OCS) system is found only on the front passenger seat. The front passenger seat OCS system is comprised of a silicone gel-filled bladder mounted in the seat cushion, a pressure sensor that is mounted to the seat frame and an ECU which is also mounted to the seat frame. Pressure is applied to the OCS system bladder when the weight of any occupant or object in the front passenger seat is sensed. The pressure is then transferred through a tube, is sensed by the OCS system pressure sensor, then electronically communicated to the OCS system ECU. Based on preprogrammed set points, the OCS system ECU will inform the RCM, via a high-speed controller area network (HS-CAN), of the necessary information. The RCM uses this information in determining if the passenger air bag module is to be deployed in the event of a deployable collision. The RCM may also use this information to illuminate/not illuminate the passenger air bag deactivation (PAD) indicator. For additional information regarding PAD indicator operation, refer to Passenger Air Bag Deactivation (PAD) Indicator in this section.
[/align]
[/align]
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
