Why did you switch from tuner X to Brenspeed?
RE: Why did you switch from tuner X to Brenspeed?
Im considering Brenspeed tunes to try also. Im currently using the Diablo tuner so I would need to switch to SCT. I currently have tunes from Doug at B-ama and have not had too good of luck with his tunes.
well i just changed my superchip to brenspeed
The differences are very noticable
1 Idle is much smoother and is lower in the rpm
2 i have a 5 speed and with superchips when i pushed in the clutch the motor rpms went up for a second then dropped Brenspeed the exact oppisite the rpms drop as soon as i push in the clutch
3 when i down shift the car slows down faster
4 of course the throttle response is a ton better
5 when at cruising speed the rpm is at least .5 rpms lower for example at 60 in fifth its at 1.2 rpms
6 less gas mileage due to lead foot, no the gas mileage is better not sure yet but i can tell
7 this is one difference that i need to be careful about when doing 70 i put in third and only put 3/4 gas and she took off and hit 110 in no time and made people around me look like they were standing still
8, spinning the tires is a ton easier.
Well i hope this helps out and shows the difference
