Metra amplified antenna install (w/pics)
#43
RE: Metra amplified antenna install (w/pics)
ORIGINAL: 2007GT/CS
3. The old antenna plug I pulled out of the back of the Shaker looked like a coax connection with a collar on it. The new antenna looks more like an RCAconnector. The new antenna lead did fit but it doesn't feel like a positive engagement. Seems to work. We'll see long term.
#45
ORIGINAL: TacoBill
After wasting an hour trying to locate a keyed 12V power source, I used an empty plug in the center console (under the cup holders) that I suspect is used for autos.
So, the official keyed 12V wire is the BLUE with YELLOW stripe.
that Taco used. I dont see a Blue/Yellow wire anywhere on the diagram.
Looks like the Violet/White wire for the OD cancel switchisa 12V
switched and fused wire.
http://iihs.net/fsm/?dir=40&viewfile...0Interlock.pdf
#46
TacoBill, you're the man.
I have the exact same antena... Been in the trunk for 6 months now[8D].
I will put it in and weld the holes shut on my fender where the OEM base is. I'll have to repaint the fender, of course, but it'll have a clean look.
Won't be no traces of an antena being there.
09-10-2015 08:39 PM
amp, amplified, antenna, ford, install, installation, instructions, knob, metra, mustang, pictures, stubby, upr, windsheild, works
