Custom vs. Canned Tune
Old May 17, 2007 | 04:11 PM
  #31
TacoBill's Avatar
TacoBill
Default RE: Custom vs. Canned Tune
Oh boy, now Scott is getting T'd! [sm=smiley11.gif]
Hopefully, I'll be getting mines dyno'd soon. I'll post up my results when I get them.
FWIW, if I ever got a S/C (or any big power mod), I wouldn't settle for anythingless than a dyno tune either.
Old May 17, 2007 | 04:24 PM
  #32
Scotte28516's Avatar
Scotte28516
Not T'd at all TacoBill, just disagreeing. How could I get T'd at a fellow BCMC'er?
Old May 17, 2007 | 05:10 PM
  #33
TacoBill's Avatar
TacoBill
ORIGINAL: Scotte28516
Exactly... so we're good!
btw- I'm getting dyno'd this Saturday. Not because of all this mind you, but I've always been curious what kind of numbers I'm putting down. I'll keep y'all posted of the results.
Old May 17, 2007 | 05:20 PM
  #34
moosestang's Avatar
moosestang
ORIGINAL: TacoBill
I'm pretty sure no tune can default the TCS to off. Of course, if I'm incorrect, I'm sure someone will point it out.
Yep, that's what Brent told me. They can shut it off, but you can't turn it back on.
Old May 17, 2007 | 05:27 PM
  #35
RedFire281's Avatar
RedFire281
ORIGINAL: moosestang
ORIGINAL: TacoBill
You can with a Predator. I change from "On" to "Off" tunes regularly.
Old May 17, 2007 | 05:38 PM
  #36
MrSandman's Avatar
MrSandman
The xcal from brenspeed will only hold 2 tunes for an 07..even though it is design to hold three. Must be something about the 07's.
ORIGINAL: ohsixgt1217
If you order it from brenspeed or something like that, yes. If you are just buying a tuner and doing it yourself, most likely not. You wont notice the throttle response differences or anything of that sort. If you order it from Brenspeed it's only like $40 more with 3 tunes in it, much better then the tuner itself.
ORIGINAL: acascianelli
Will I still see these amazing improvements everyone is seeing if I stick with the canned C&L tune?
Old May 17, 2007 | 07:24 PM
  #37
Scotte28516
ORIGINAL: RedFire281
ORIGINAL: TacoBill
+1
Old May 18, 2007 | 05:28 AM
  #38
FordDude's Avatar
FordDude
Yes your TCS can be defaulted off, but I don't think it's the best way to go for all around safety reasons.
When I say that I want the TCS defaulted to off, what I wantis to have to push the TCS button if I want the TCS on. Now as part of my startup procedure I hit the TCS button to turn it off. fd
Old May 18, 2007 | 07:07 AM
  #39
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I did the dyno tune because of a tuner that is a friend and I got a deal! Nothing wrong with canned but I prefer a dyno tune. Like you said TacoBill esp if you get a S/C!
ORIGINAL: TacoBill
Old May 18, 2007 | 09:51 AM
  #40
06SaLeEn's Avatar
06SaLeEn
I ♥ Acer
IMO when you go F/I you spend close to 5-8k depending on the set up. Would you by a Bently and put it through a car wash? know then why would you spend 5-8k on a set up and not splurge for a Dyno tune. IMO you can get away with a Canned tune or Custom Canned tune or whatever you want to call it on mods minus the F/I but after you get the F/I you got to Dyno Tune
