problem under the hood--->solved!!!
Old May 17, 2007 | 11:00 PM
SeanoStang's Avatar
SeanoStang
Default RE: problem under the hood
the mechanic at the dealership said its steam from the over flow and that it happens but i dont like it at all
Old May 17, 2007 | 11:07 PM
StantheMan's Avatar
StantheMan
Seanostang, I tried the link and it came up in an error, when it comes to the spewing of the overflow canister, this is not normal, double check the actual radiator cap and make sure its tight, it could be a sticky thermostat, I have never seen a vehicle, Ford or otherwise spew coolant without some type of cooling system problem. This may seem over simplification of the problem, try a different dealer if possible.
Old May 17, 2007 | 11:08 PM
spuddogg's Avatar
spuddogg
ORIGINAL: SeanoStang
But where's the steam coming from?
And while it is an 'overflow' reservior it's more of a fail-safe - not a normal operation type-thing.
The spewing part is the kicker here.
Take it back, if it's the same tech then ask to speak with the service manager.
Not to mention the possibility of an engine cooling issue (a very bad thing) the 'spewing' of coolant from the reservior cap will cause cosmetic damage over time (and possibly even damage to hoses, belt, etc.).
Basically, my advice is when you spend $30k for a car, don't be afraid to be an ******* if necessary if you don't feel you're being taken care of.
Too often, that's the only way to getafire lit under someone's butt.
Old May 17, 2007 | 11:11 PM
SeanoStang's Avatar
SeanoStang
i going to take it in toorrow for sure after class because it really worries me. and yes its from the overflow res. and do you think its covered by warranty? i sure hope so and i dont see why not. i guess we'll see tomorrow
Old May 17, 2007 | 11:17 PM
StantheMan's Avatar
StantheMan
I reread your thread, if the overflow tank on the top was leaking before you opened it, there is a pressure leak somewhere in the system that needs to be detected or you will always have an overheating condition. If you opened the cap with the engine hot, while under the system pressure, then it would be perfectly normal for coolant to spew out, this is why most radiator systems always have a safety notice not to open when hot and under pressure.
Old May 17, 2007 | 11:19 PM
spuddogg's Avatar
spuddogg
Definitely should be a warranty issue.
For what it's worth, I get the impression you're a young guy.
It's not uncommon at all for these guys to take advantage of your age and try to intimidate or BS you.
If at all possible, bring an old fart with you.
Even if he just stands there and says nothing, sometimes having a gray hair or two around can change up the equation.
If that's not possible, keep your cool, don't get pissed (at least not visibly) and don't take 'No' for an answer.
Good luck and keep us posted.
Old May 17, 2007 | 11:20 PM
GidyupGo's Avatar
GidyupGo
Maybe they just overfilled it. The cold fill line is just an inch below the cap level. Not much room for expansion.
Old May 17, 2007 | 11:55 PM
SeanoStang's Avatar
SeanoStang
i was also thinking that gidy...i hope thats all it is
Old May 18, 2007 | 01:17 AM
SeanoStang's Avatar
SeanoStang
anyone else?
also i want to add that no lights were on on the dash telling me somethings wrong.
and im guess if it was a bigger problem, the car comp would tell me
right?
Old May 18, 2007 | 03:12 PM
SeanoStang's Avatar
SeanoStang
takin her in today to check out whats up
