problem under the hood--->solved!!!
Old May 17, 2007 | 09:17 PM
SeanoStang's Avatar
SeanoStang
Default problem under the hood--->solved!!!
so i popped the hood after a drive last week and found that the cap near the front of the engine (maybe radiator?) was letting fluid out. the dried liquid leaves a white residue around the cap. i brought it to the dealer and they said its normal and its just gonna happen. well today after a drive i popped it open again and the cap is.....spewing. the fluid was flowing pretty well
im not sure this should be happening
any ideas?
EDIT it was a faulty overflow cap
Old May 17, 2007 | 09:20 PM
ilmor's Avatar
ilmor
Default RE: problem under the hood
Do you have a picture of this cap? What was your engine temp. reading? Anything spewing is not normal.
Old May 17, 2007 | 09:23 PM
SeanoStang's Avatar
SeanoStang
the cap to the left of the intake tube
SeanoStang's Avatar
SeanoStang
try this pic
Old May 17, 2007 | 09:35 PM
SeanoStang's Avatar
SeanoStang
nobody?
Old May 17, 2007 | 09:37 PM
SeanoStang's Avatar
SeanoStang
http://www.moddedmustangs.com/wp-con...engine-bay.jpg
the pic is here
Old May 17, 2007 | 09:41 PM
ilmor's Avatar
ilmor
I can't get that link to work...
Old May 17, 2007 | 09:44 PM
SeanoStang's Avatar
SeanoStang
it wont let the site show up
its on modded mustangs .com
the **** is modded mustangs
no space
Old May 17, 2007 | 10:23 PM
SeanoStang's Avatar
SeanoStang
nobody else has had this problem?
Old May 17, 2007 | 10:35 PM
spuddogg's Avatar
spuddogg
If I'm looking at it right, it's coming out the radiator overflow reservoir?
That's most certainly not 'normal'.
