TacoBill's 1st trip to the dyno!
Great news! Engine didn't blow-up!
Dyno run was performed at Swanson Performance in Torrance, CA (same guys that installed my 4.10 gears).
Swanson gave me the run files, so I downloaded the Dynojet viewer program and messed around with the Corrected (SAE) vesus Uncorrected graph displays. Pics below. Numbers (0, 3, 5) refer to the Smoothing Factor.
I set the A/F reference line at 13.0. I don't know how to display high/low peak numbers on the A/F graph, but highest spike was 12.9 with the average being 12.5 - 12.8.
Note: Wideband sensor was plugged into the driver's side rear O2 bung in the O/R-H. Doug's tune deactivates the rear O2 sensors, so disconnecting it was not a problem.
Note: All runs were with Doug's 91 Race Tune.
Note: Pulls 1 & 2 were done back-to-back. 10 minute cool down before pull 3.
Oh yeah, I'm happy as hell with the numbers I put down!!! [8D]
YouTube dyno pull video
1ST PULL VIDEO OF A/F READING
SAE CORRECTED: SMOOTHING 0
SAE CORRECTED: SMOOTHING 3
SAE CORRECTED: SMOOTHING 5
UNCORRECTED: SMOOTHING 0
UNCORRECTED: SMOOTHING 3
UNCORRECTED: SMOOTHING 5
RE: TacoBill's 1st trip to the dyno!
I understood the first 2 lines of that!
"I just drive 'em... I don't know about fixin' 'em"
What other sort of work does that shop do for our Mustangs? I don't dare take off a bolt with my butterfingers!
Well, Im still learning the language of the dyno but regardless of what I do and dont know, I absolutely love the crapp outta watching dyno videos!!!!! Excellent!!! [sm=smiley20.gif]I cant wait to get mine done this summer!!!!!
ORIGINAL: kenthicken
Bill, if you don't mind my asking, how much was your run at Swansons? Curious to see how the Brenspeed tunes are doing - especially the A/F ratio.
I've read that Doug's and Brenspeed's tunes are on par with each other, so I would assume the A/F ratio will be good too.
ORIGINAL: HDmstng
What are you mods?
Great write-ups by the way!
What are you mods?
ORIGINAL: Orion_240
ORIGINAL: howarmat
What numbers would consider you peaks?
I mean, at SAE, I peaked at 317.65 at the 0 setting, andat 291.82 at the 5 setting. Why the huge spread?
jwog666
12-27-2021 08:09 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
