CAI install question
Old May 25, 2007 | 06:35 PM
americaniron's Avatar
americaniron
Default CAI install question
I recently purchaced a JLT cai, and SCT from Brenspeed. Do the custom tunes come already loaded on the tuner, or does it need to be loaded to the tuner from the provided disc? Or is the disc just a back up?
Old May 26, 2007 | 12:20 AM
Blinkwise's Avatar
Blinkwise
Default RE: CAI install question
disk is for you to do different things, but the tunes that brenspeed gave you are already on your tuner, i installed mine today before even messing around with the disk
Old May 26, 2007 | 01:01 AM
americaniron
Cool . Thank you very much. I'll probably install in the morning.
Old May 26, 2007 | 02:12 AM
GTstangB.F.D.M.'s Avatar
GTstangB.F.D.M.
waht does the disk do?...
and how do i hook up to the computer to download a tune (i have the SCT also)
Old May 26, 2007 | 02:15 AM
blackout's Avatar
blackout
David,
Plug the SCT X-Cal 2 into the OBD II Port which is below the driver side dash(steering column) and scroll down from the main menu and download the tune to your PCM. It's very basic once you plug it in, it will erase the stock calibration after you select the new one and then it will automatically load the new tune on as well.
Good luck, hope to see you come by the shop soon.
Edit: You only have to download the tune onto the tuner if it is not already supplied on the handheld device. When you get your tuner from Brenspeed it will already be pre-programmed and you just have to follow the steps I listed above.
You may download a custom tune file that you order online or an updated file that is sent to you through SCT Livelink 3 which is an .ll3 file and is basically done by following the software information on the SCT website. You will need the USB cable in order to link your X-Cal 2 to your computer and download an updated tune onto your device.
-Jeff
GimpyHSHS
Aug 29, 2015 06:30 PM
my96mustang
Aug 24, 2015 06:12 AM
SoZoomMe
Aug 19, 2015 03:54 PM
Darrens07GT
Aug 10, 2015 03:59 PM
Mnuckolls
Aug 9, 2015 08:54 AM
