Help with CDC Shaker hood scoop
RE: Help with CDC Shaker hood scoop
Well i emailed cdc and got the info i needed here is what they replied if your intereted.
Hello!
Thanks for the interest and email!! The holes that are left when removing the factory scoop will be the entire row of holes nearest the windshield. It would not be a problem to send a template if it will help you plan your installation. However- I do have a suggestion that may help. If you remove your under-hood blanket, you will see a large recess in the center of the hood. We worked with Ford on the design of the hood, and that recess is stamped there specifically for our Shaker system. The hole in your hood for the Shaker will fall within that recess.
As another suggestions, I’ve spoken with a number of customers that took their vehicles back to their Ford dealership and were able to swap hoods for a similar-color hood with no scoop. It is usually done with no cost, as the dealer is getting a free hood scoop out of the deal.
I hope this helps! If there is anything else I can assist with, please let me know. Thanks again,
Hello!
