ready for nitrous...please help
ORIGINAL: ZZmustang
Where did the ones that have Nitrous, tap into a Gas sourse, for the wet system?
Unsure about the ZEX setup, but the NOS setup comes with a billet plate that goes between the FRPS and the fuel rail, then the line goes into that block.
ZEX is a plate set up also...NX has a plate set up and a nozzle set up. the nozzle set up requires afuel fittingthat plugs into the back of our fuel rail on the 3 Valves. That is how the guy at nitrous express explained it to me...
This is a portion of the email he sent me this morning...
The fuel fitting is part number 16183. You can see it here:
http://www.shopatron.com/product/par...er=16184/300.0
It simply plugs into the back of the rail. There is no modification
required. It's a simple bolt on. Without it, you would have to fabricate
something. This part was designed so there wouldn't be any difficulty or
risk installing the kit.
Nov 10, 2015 11:39 AM
