Lowering Question
Old Aug 2, 2007 | 10:28 AM
forrestgump's Avatar
forrestgump
Default Lowering Question
Hey i have been reading some MF posts about lowering the back end and I read on one post that it its any easy mod but my question is, is there a write up some where and can someone giveme a link to some good springs and all the things i need to do the job.
Old Aug 2, 2007 | 10:35 AM
Dex's Avatar
Dex
Default RE: Lowering Question
Eibach Pro Kit
Taco Bill has a write up
Old Aug 2, 2007 | 10:36 AM
JayFi's Avatar
JayFi
Here's the writeup TacoBill did:
Spring Install
Roush sells the front and rear springs separately... so if you're only doing the back end that might be a good choice.
Old Aug 2, 2007 | 10:37 AM
forrestgump
ok thanks and right after i posed this i saw that post about the lowering right under me im a DA oh well thanks.
Old Aug 2, 2007 | 10:42 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: JayFi
Spring Install
Moss Mustang sells Roush rear springs by themselves ($130).
I would recommend the Roush rear shocks ($180)as
well as the Roush rear springs to match them up
properly. I have them on order along with Poly
Bushings for the panhard bar as well as the rear
sway bar. Installing them next weekend if they
arrive on time. Supposed to be a 3/4" drop.
Old Aug 2, 2007 | 10:46 AM
forrestgump
awesome let me know how it turns out, you doing the install yourself?
Old Aug 2, 2007 | 11:07 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: forrestgump
Yes I am. I'll take pics if you so desire but Taco
already covered it, I believe. I have the shop
manual andmost of it is covered. They recommend
new hardware most everywhere on the suspension
parts but I think a little locktite and the proper torque
specs is all that will be needed. PM me if I dont get back
to you after this weekend.
Old Aug 2, 2007 | 11:16 AM
forrestgump
Ok will do.
Old Aug 2, 2007 | 04:04 PM
blaven's Avatar
blaven
The rear install is cake, jack up the back under the rear diff.(I loosen the lug nuts first so they are loose but not off), put 1 jackstand on each side of the frame rails, remove the lower shock bolts and the brake line bolt so you don't stretch the lines, then the sway bar bolts which aren't really necessary i just like to do it since you get a little more play in getting the springs out. After i've done it 4 times now i can get it taken apart and done in about an hour. Good luck!
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
