ETHONAL BAD
Old Aug 28, 2007 | 12:11 AM
Ford_Dude's Avatar
Ford_Dude
Default RE: ETHONAL BAD
its not that is less combustable but that it has more energy (chemical potential) and needs more energy to ignite but also releases more
http://www.prime-mover.org/Engines/G...es/octane.html
so by needing more energy to ignite it prevents preignition more
also the way the gas comps change octane usualy involves mixing a verious hydrocarbons (to low and they add a heavier hydocarbon)
for instance the way they boosted oct in the old days was lead it was cheap and easy but didn't really add energy
have you ever burned candle wax (not by wick but actualy the wax its self on fire without a wick)
now wax has alot more chemical potential than gas so it takes a lot of energy to really ignite and gives off alot of energy (enough to crack glass with pure heat)
Old Aug 28, 2007 | 01:23 AM
ollied's Avatar
ollied
wouldn't run e85 in an engine not designed or prepped for it..think all gas now comes with some level of ethanol
Old Aug 28, 2007 | 01:37 AM
owero01's Avatar
owero01
Leave Walmart and go to BP. I only use BP or Exxon period. Not taking the chance on WAWA, Walmart, COSTCO, etc.
Old Aug 28, 2007 | 01:53 AM
lldsandsll's Avatar
lldsandsll
exxon is mobil. also chevron, sunoco, and a couple other places are pretty good.
Old Aug 28, 2007 | 06:23 AM
BigDave's Avatar
BigDave
Actually, the 15% alcohol that you are talking about is what used to be referred to "gasohol."
Up to 15% is safe for your engine. Over that and certain parts of your fuel system (specifically butyl rubber, but also some coatings, such as fuel tanks in older cars) will deterioriate.
Alcohol actually has LESS energy than gasoline. That is the reason that the stochiometric formula is 14.7 parts of air to one part gas for gas and roughly10.5 (depending on methanol or ethanol) parts air for 1 part of alcohol. Race cars use it for it higher inherent octane (can build a motor with higher static compression ratio) and greater charge cooling given the higher consumption of fuel.
I does have the downside of increased engine wear and increased absorption of water vapor.
Old Aug 28, 2007 | 08:32 AM
howarmat's Avatar
howarmat
s197 Junkie
e85=bad for our cars
walmart=bad for civilization in general
find a different place to shop period
Old Aug 28, 2007 | 08:55 AM
Leoleo's Avatar
Leoleo
All gas in the US has Ethanol in it at 15% for anything that is not E85. Ethanol replaced the other additive (MTPT sp) that congress outlawed due to it can cause cancer and was getting into the water tables.
As for gas in general. You do know that the gas you buy at your local gas stations, any gas stations, are refined in the same refinery. Gasoline is shipped in the country via pipe lines. In Delaware it is all refined at the Valero Refinery in Delaware City. The local companies simply put additives in the gas after it has been placed in the tanker truck that delivers to the stations. The Discovery Channel or History Channel has a story on gasoline. I think it was one of the Modern Marvels shows. All gas is pretty much the same, major differences are octane ratings, and location in the country. North East America has a "cleaner" burning gas then say the Midwest.
Just buy the gas based on price. You will always have a chance to get so "bad" gasoline.
Old Aug 28, 2007 | 09:07 AM
A_J's Avatar
A_J
ORIGINAL: Local Yokel
I would say the problem is filling up at Walmart ...
I heard that Walmart gas is made from recycled lead paint
Old Aug 28, 2007 | 09:35 AM
schapman's Avatar
schapman
+1
ORIGINAL: Leoleo
Old Aug 28, 2007 | 09:41 AM
schapman's Avatar
schapman
I think what he's was trying to say was the E15 gas everyone uses is not made by mixing E85 to our gas. Its made by mixing E100 to normal gas to create the E15. so the put 85% gas and 15% Ethanol together to make our gas.
ORIGINAL: Sleeper05
ORIGINAL: TxLonghorn
ORIGINAL: Sleeper05
e85 ethanol is not dangerous to your motor. It will only be mixed up to about 15% by volume. The simple fact that it is potentially in there will NOT affect the octane rating, because the mixture will still have a minimal rating of 87.
Actually, e85 would be 85% ethanol. If its 15%, then its E15, so in that case, E85 would be dangerous to your engine. [8D]
No chit. What you failed to read into is that I was referring to HOW MUCH of the volume of the gas was actually e85. That number would be *up to* 15% depending on the state.
