what offset for wheels?
Old Sep 3, 2007 | 07:31 AM
one eyed willy's Avatar
one eyed willy
Default what offset for wheels?
im going to go with 19's i think,probably 8.5 wide in the front and 9.5 in the rear.what offset should i be looking for?
Old Sep 3, 2007 | 10:15 AM
Black3vGT's Avatar
Black3vGT
Default RE: what offset for wheels?
Stock offset is 45mm, so the closer to that the better.
Old Sep 3, 2007 | 11:13 AM
fairlane292's Avatar
fairlane292
ORIGINAL: Revlefty
Yeah, 45 on the OE 17x8, believe it's 50 on the 8.5's. Try to get at least the 45, 50 if you can(particulary on the 9.5) ...though you won't notive diff in 45 and 50 anyway. The more the better on the 9.5's. Test fit rims before mouting tires (mount them you own them).
Old Sep 3, 2007 | 12:13 PM
one eyed willy
the ones im looking at for the rears are 19x10 with a 40 offset and a 19x8.5 for the front with a 24 offset.would 24 be closer to the fender or further inside???
Old Sep 3, 2007 | 12:59 PM
bazguitarman's Avatar
bazguitarman
On the aftermarket it looks like 40mm is the common off set. I`ve also seen a lot of 24mm offset wheels, but I think they stick out too far. I`m gonna put 18" x 9" Razors on my GT and I`m going with the 40mm offset front and back with 255/45/18 tires.
Eric
Old Sep 3, 2007 | 01:11 PM
fairlane292
Front and back will both stick outward in the fenderwellmore thanOE by 1" with those offsets. Should look even front to back; if you like the look of the rims/tires outward more than OE than you'll like this. I prefer the rims/tires more inside like OE but I also cannot afford to have dirt kicking up onthe front fender with the custom paint. If your's is a daily driver, you will get some chipping/"sand blasting" behind rear tires with this but that area can be prof touched up every couple years pretty inexpensively. You should be fine; just mount a fr and rr rim w/o tire before having the tires done; check for clearance and how you like them being outward that inch (although not the same as having tire mounted and car down on the ground you can get an idea before making the final commitment)
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
