gauge install. please help
Does anyone has a guide or pics of oil pressure and water temp gauges install, i have the gauges and the pod reay and wired up. i just want to know how do you guys wired yours up and where did you plug the water temp sender. and the cables. some pics at least thanks
I can't help you with water temperature, but I did do a write up on how I installed my oil pressure gauge a little earlier this year.
https://mustangforums.com/m_3043821/tm.htm
My decision to mount the sender to the block was controversial for some, everything is included in the post, though.
If you still have questions about the wiring, then post back. I'll try to answer them as best as I can remember.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
