Parking Brake Switch for audio system
Old Sep 23, 2007 | 11:42 AM
shockme76's Avatar
shockme76
Default RE: Parking Brake Switch for audio system
Save yourself a lot of trouble and just ground the wire. There a very few models where grounding the wire doesn't work.
There is no "switch" but more of a button that is released whenever the ebrake is engaged.
Old Sep 23, 2007 | 11:54 AM
howarmat's Avatar
howarmat
s197 Junkie
There is no "switch:. Pull up the console byh the ebrake and all you have to do is connect it to one of those wires. But usually for the bypass you just ground the parking brake wire. If you are not interested in the bypass then just hook it to the wire in the parking brake connection.
Old Sep 23, 2007 | 12:56 PM
Gaspi101's Avatar
Gaspi101
ORIGINAL: 157db
ORIGINAL: Gaspi101
"The SJB receives the signal from the praking
brake switch via a standard wire"
Where is that standard wire? Under the console? Does that mean I have to run the pink cable next to where the transmission is, under the center console? Thanks.
ReRead the above post. No, you dont have to run
a wire all the way to the center console.
"I'll check the workshop manual and post the wire
color. You can then maybe pick it up at the SJB
located under the passengers side kick panel. "
Looks like you need a step by step process.
Step 1 Remove the passengers side door sill plate.
Step 2 Remove the passengers side kick panel
Step 3 Remove the nut holding the SJB to the A pillar
Step 4 Pull the SJB out from the bottom until it unhinges and hangs free
Step 5 Find the right wire on one of the 7 or 8 connectors and 100s of wires
Step 5 Strip the insulation back avoiding damaging the copper conductors
Step 6 Find a wire of the correct size and attach it to the wire and solder
Step 7 Run this wire under the dash to the head unit and attach
Step 9 Reverse the order of steps 1-4 and reinstall the items removed
lol. Thanks! I appreciate your instructions, my friend. I'll try first attaching it to a ground, but I don't think that will work on my UV8 (since it doesn't work on the Jensen 9312--disabling requires a pulsing connection, not a steady one). If that doesn't work, and I can't find the "parking brake switch" cable, I'll just jerry-rig a little button that will make negative contact by pressing it. Thanks everyone. :-)
Old Sep 23, 2007 | 01:04 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Gaspi101
ORIGINAL: 157db
ORIGINAL: Gaspi101
The parking brake/console harness runs right next to the center dash area
and you could find the needed wire there. I'll get the specifics from the
workshop manual and post them tomorrow.
Old Jun 17, 2019 | 09:04 PM
Gentry S Harvey's Avatar
Gentry S Harvey
Default Ebrake radio wire
Which wire does it connect it to on my hand brake for my stereo. There is one tht screwed down like a ground wire and another live wire it looks like but idk.. So which one is it do you know..
Old Jun 28, 2022 | 06:20 PM
Dando's Avatar
Dando
Default Parking brake wiring.
I just did an Alpine ILX-W650 IN AN 07 MUSTANG. HERE IS WHAT I DID. WITH THE RADIO HOOKED UP IN THE HARNESS I TURNED ON THE RADIO. IT WORKED. NOW FOR THE PARKING BRAKE SWITCH. THE YELLOW WIRE BLUE STRIPE I BUTT SPLICED A YELLOW WIRE I BOUGHT AT AUTOPARTS STORE LONG ENOUGH TO REACH THE PARKING BRAKE HANDLE.. THERE ARE 2 WIRES ON THE SWITCH. IT DOES NOT MATTER WHICH WIRE YOU SPLICE INTO.. IT WORKS EITHER WAY! I TOOK A WEED TRIMMER STRING AND FISHED IT TO THE RADIO. I then taped the yellow wire to the trimmer line AND FISHED THE WIRE TO THE SWITCH WIRES. I CUT ONE OF YHE PARKING BRAKE WIRES AND SPLICED ALL THE WIRES TOGETHER. I mean the yellow into the cut wire. Turned the radio on again, hit the parking brake up, down, up again.. It works! Their instructions SUCK!
Old Jun 30, 2022 | 10:59 AM
Dando's Avatar
Dando
there is none....
on my 2007 mustang, the switch is attached to the parking brake. CHOOSE EITHER of the 2 wires, splice the stereos parking brake wire in.. easy.
Dirty Work
Convertible Tech
Jul 17, 2019 10:25 AM
r1sky5.0
Aug 7, 2010 09:40 PM
89foxneedslove
Aug 3, 2010 11:12 PM
sfi
Jun 29, 2009 10:24 PM
hookedonkronik
Jun 2, 2006 12:49 PM
