Trunk stuck
Old Sep 23, 2007 | 10:00 PM
pxdig's Avatar
pxdig
Default Trunk stuck
Quick question,
It seems every time I want to open the trunk, with either the key or the remote, it gets stuck. I usually have to press the button four or five times or turn the key the same amount of times to get it to open. Its already out f warranty, so, how do I fix this ?
Old Sep 23, 2007 | 10:03 PM
hammeron's Avatar
hammeron
Default RE: Trunk stuck
i'd look at the weather stripping and make
sure it's not misaligned
Old Sep 23, 2007 | 10:45 PM
ohnoesaz's Avatar
ohnoesaz
After you unlock it, push down onthe emblem, the trunk will click and you can lift it up.
Old Sep 23, 2007 | 11:07 PM
Orion_240's Avatar
Orion_240
Is it the actual lock? Mine used to stick, so I'd have to force it open. Used silicone spray on the rubber and it eventually stopped and hasn't come back. Pretty sure there wasn't anything wrong with my lock.
Old Sep 25, 2007 | 12:14 PM
jerjan's Avatar
jerjan
Could be the latch is not adjusted properly.
Old Sep 25, 2007 | 06:13 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Yep, latch's dragging or thestriker moved a bit.
Old Sep 25, 2007 | 06:17 PM
downriverT's Avatar
downriverT
Get out the BFH and have a whack or two at it.
Old Sep 25, 2007 | 07:21 PM
maniacmikey's Avatar
maniacmikey
Blame your wife and get a new Stang.
Old Sep 25, 2007 | 07:24 PM
drbobvs's Avatar
drbobvs
Mine does it too, it's a PITA. I've looked for a latch adjustment, there is none on the trunk lid, I'll have to look at the base some day.
mrtrodonet
Sep 19, 2020 03:12 PM
jstrothe
Sep 24, 2015 12:17 PM
rafotree
Sep 22, 2015 03:55 PM
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
