Please explain wheel off-set
Old Oct 3, 2007 | 08:35 PM
Jackies Stang's Avatar
Jackies Stang
Default Please explain wheel off-set
Not quite sure the true definition of this term. Is it in relation to the front tires compared to the back or is in relation to the factory location. The look i am looking for is to have 9's front and 10's rear but dont want the rear tires to track wider than the front! I personally like the factory tire location but would like the rear wheels wider but tucked inward torwards the differential. Almost like a tubbed out drag car! Can someone please explain the terms and if anyone has pics, i would love to see them! Thanks!
Old Oct 3, 2007 | 08:37 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Please explain wheel off-set
He is a good pictorial of it
Custom wheels, chrome wheels, alloy rims - BIGCUSTOMWHEELS
You can change the offset and see how the wheel setup changes with it
Old Oct 3, 2007 | 08:48 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Factory offset has the rear wheels out farther than the front wheels anyway.
Old Oct 4, 2007 | 08:04 AM
rogan01's Avatar
rogan01
What is the stock offset for 18" wheels? (fanblades)
Old Oct 4, 2007 | 08:27 AM
Stang Girl13's Avatar
Stang Girl13
The offset of the fan blades are 45mm.
Old Oct 4, 2007 | 09:22 AM
rogan01's Avatar
rogan01
Thanks Stang Girl!
Old Oct 4, 2007 | 09:37 AM
moosestang's Avatar
moosestang
offset is how far off center is the mounting surface of the rim. If it's offset towards the inside edge of the rim it's negative, if it's offset towards the outside edge of the rim it's positive. obviously if the mounting surface is right in the center of the rim it has a 0 offset.
Ever see a car or truck driving around with rims/tires that stick way out compared to stock? That's because they bought rims not made for the car with a negative offset.
Old Oct 4, 2007 | 10:16 AM
torch red's Avatar
torch red
Actually the 18" Factory is 50 mm the 17 " is 45 mm
I feel the off set is not aggressive enough...The tire should be even with the fender ..that looks best..
Mine are 38 mm front 18 x 9 42 mm rear 18 x 10..they line up with fender perfectly..
ORIGINAL: rogan01
Old Oct 4, 2007 | 05:02 PM
ErcWrestlr's Avatar
ErcWrestlr
ORIGINAL: torch red
ORIGINAL: rogan01
any pics TorchRed?
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
mrappe
Sep 26, 2015 10:16 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
