5x115 rims on a mustang?
Hi folks,
I was wondering if its possible to fit the 5x115 bolt pattern rims on a mustang. I believe the mustang is 114.3? If anyone has done this, did you need to use hubcentric rings? I'm wondering if it would be ok to do this. let me know what you think.
Cheers,
ponypit
Cheers,
ponypit
RE: 5x115 rims on a mustang?
Umm... are you serious?
You would need to use a full on wheel adapter, not just a hub centric ring. The 114.3 and the 115 refers to the spacing of the lugs, not the hub ring size. So, from the two furthest lugs away from one another, it measures 114.3 mm (or 115 mm).
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
