putting in coilovers,what else should i do while under there?
in about 1 month i will be doing my coilovers,what should be considered at the same time?i will be doing my exhaust,tires and kit but what about other suspension mods,what is critical and would make the most of my time and $$.
depends on what you are setting your car up to perform best at. I am installing aluminum coil over struts with fox body spindles to be able to put lightweight willwood brakes on the front as well as a chromoly k member and front lca's to reduce weight on the nose of my car for better and quicker weight transfer for drag racing. If you are setting yours up for better and stiffer handling for road racing you would probably take a different aproach.
1996cobraconvertible
SVT Forums
13
Jan 7, 2016 04:50 AM
LivingInThePast
Sep 16, 2015 12:20 PM
