Just added the Shaftmasters aluminum drive shaft
Ford uses the two-piece due to torque & NVH. There is no slip shaft on the end of our trannys, the driveshaft bolts to a hub. The slip shaft is built into the Ford driveshaft. This is where all of the clunking you hear between shifting gears is found. Should be no problems for the alum. d/s, as a lot of vehicles come from the factory with this, and actually have less rust than a steel unit. The spydershaft is actually based off of a ranger d/s.
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Urambo Tauro
Aug 27, 2015 10:53 AM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
