Front speakers don't work
Old Nov 1, 2007 | 07:41 AM
  #21
deweirdt's Avatar
deweirdt
Default RE: Front speakers don't work
Also, I set the HPF on my aftermarket headunit to 100Hz and don't hear any sound from those speakers unless it's pretty harsh bass...not sure if you can do that with the stock Shaker 1000??
No I don't think you can change the HPF on the shaker1000.
Old Nov 1, 2007 | 07:51 AM
  #22
hammeron's Avatar
hammeron
email sent, i hope you can find
the problem
Old Nov 1, 2007 | 08:04 AM
  #23
deweirdt's Avatar
deweirdt
Looks perfect. I'm going to enjoy myself this afternoon
I'll report back as soon as I found something (or nothing
Greetz
Old Nov 1, 2007 | 09:13 AM
  #24
deweirdt's Avatar
deweirdt
Ok I'm already back. I found something interesting. When I run the walk-around diagnose (press button 3 and 6 to activate walk-around test) then my RF, LF, LR, RR are working very good. Then the test is going to the Subwoofer I and Subwoofer II.
There I noticed a problem with the SubwooferI. I hear a very low noice (bass) trough them. A big difference with the one in the back (subwooferII).
For the once that have the diagnostic document 415-00-23 I'm following Test point F.
According to the diagnostic papers, I should check for Connector Circuit C536. But I don't have an idea were it could be. Also I don't have a clue what I should measure.
Anyway if I should be able to locate the circuit bord and I'm able to take it out. Then I'm able to provide it to my Hardware engineers that will certainly find the right components that are broken.
A second problem I have noticed while going trough the DTC's was that I found the error U1900 what is meaning: CAN Communication BUS Fault - Receive ERROR (hmm very interesting [:-] )
Greetz
Old Nov 1, 2007 | 09:26 AM
  #25
deweirdt's Avatar
deweirdt
For the people who want that document:
http://pjdeweirdt.desneppe.be:8080/2...iagnostics.pdf
Greets
Old Nov 1, 2007 | 09:30 AM
  #26
DocVenture's Avatar
DocVenture
The connection could be bad to the actual speakers, the amps which are under the drivers side kick panel (So I've been told, I haven't checked), or into the back of the head unit. There is a seperate harness that runs to those speakers.
Old Nov 2, 2007 | 04:50 AM
  #27
deweirdt's Avatar
deweirdt
Hi,
Can somebody provide me with a wiring diagram of the audio system. I need to check if I get power for the subwoofer I amplifier?
Also I need to know where this one is located? So that if needed I can easily find him and replace him.
greets
Old Nov 2, 2007 | 08:29 AM
  #28
deweirdt's Avatar
deweirdt
Guys,
Another idea! If I should measure the voltage on the fuse 16? What should this be? My guess would be that I should have 12V on that. Is that correct?
Greetz
kdryan
Aug 26, 2015 05:54 AM
Elcameeeno
Aug 19, 2015 11:19 AM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
cema93
Aug 10, 2015 09:35 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
