My $4 theft "deterrant" system
Old Nov 2, 2007 | 09:37 PM
dewittalday's Avatar
dewittalday
Default My $4 theft "deterrant" system
I created my own theft "deterrant" system and thought I'd share since I don't have a "real" anti-theft system. I purchased a $4 blinking LED kit from Radio Shack (part # 276-299) and mounted it inside my driver side mirror control. Here's some notes:
[ul][*]Tools: Dremel, epoxy (for plastic-to-plastic), blinking LED, 2 AA batteries[*]I drilled a small hole with the Dremel for the LED to stick out of (see pics).[*]I routed out a small hole using the Dremel for the switch (see pics). You'll notice I put this hole in a spot so it can't be seen when the door is closed, but you can quickly and unsuspiciously get to the switch when you open the door. It is just large enough to get my finger into.[*]The LED and battery pack were mounted using 2-part epoxy (for plastic-to-plastic surfaces). Notice that I mounted the battery pack so the batteries could be easily inserted or removed.[*]Once the epoxy set, I mounted the mirror control.[/ul]Another idea was to hard-wire a blinking LED to a "hot" wire so that it didn't require batteries, but I liked the separate battery option the best. There is a tight fit between the battery pack and the alignment stubs sticking out from the mirror. I did not take a picture of this, sorry. I had to leave the battery cover off in order for the mirror control to go back on.
I figure people will think I have some kind of "custom" anti-theft system if they see it.
[IMG]local://upfiles/51810/8EF145408E484574AD4905D09F5CEE5C.jpg[/IMG]
[IMG]local://upfiles/51810/630FA68E02CA420BB15EB0AD26581541.jpg[/IMG]
[IMG]local://upfiles/51810/B45F7F539E904280943372D67758C945.jpg[/IMG]
[IMG]local://upfiles/51810/7AE4E2BB56EF4744829262B02D424C9C.jpg[/IMG]
[IMG]local://upfiles/51810/2F90551BBACC47F2A5F8D50A1DED1F0A.jpg[/IMG]
Old Nov 2, 2007 | 09:38 PM
07BLACKGT's Avatar
07BLACKGT
Default RE: My $4 theft "deterrant" system
Cool!
Old Nov 2, 2007 | 09:52 PM
Ford_Dude's Avatar
Ford_Dude
you should have used a Red led
colors have a psychological effect and red is more of a warning effect
Old Nov 2, 2007 | 10:02 PM
howarmat's Avatar
howarmat
s197 Junkie
Can you switch out the LED for different colors....i see that the default is red but i want blue!
Old Nov 2, 2007 | 10:30 PM
5SPD07GT's Avatar
5SPD07GT
Official Site Sponsor
any pics at nite?
Old Nov 3, 2007 | 02:44 AM
alloutt's Avatar
alloutt
let me know if someone breaks into your car because they think something important is in there.
Old Apr 10, 2008 | 04:03 AM
Ortoch's Avatar
Ortoch
sorry to resurrect this post but I think this is a pretty cool idea
Old Apr 10, 2008 | 06:16 AM
SumterBoy's Avatar
SumterBoy
Good idea, old post but still pretty cool
Old Apr 10, 2008 | 07:17 AM
TPony's Avatar
TPony
Super idea...
Old Apr 10, 2008 | 07:28 AM
chain1's Avatar
chain1
When I was in highschool, someone broke into my '86 Scirocco and stole my radio so I installed the exact same thing. Two days later someone broke into my '86 Scirocco and stole my radio. Not sure where I'm going with this but, suffice to say, I don't think it worked in my case.
Forgot to mention that my LED was even red!
