head lights aiming
Old Nov 6, 2007 | 09:19 PM
07Mustang's Avatar
07Mustang
Default head lights aiming
2007 mustang my head lights are to low how do you adjust them
Old Nov 6, 2007 | 09:27 PM
GTstangB.F.D.M.'s Avatar
GTstangB.F.D.M.
Default RE: head lights aiming
its sooo easy.. but its hard to explain.. get your manual, and read what it says, and it will show you a diagram.. its simple.. all you need is a screw driver...
BUT
becareful with how much you play with the aim.. i did it and turn them proably like 8 turns.. and now they point right in everyones eyes as if the brights were on.. now every flashes me as they go by, and i just havnt got around to lowering them..
i would say like 2 complete turns would be good.. but, good luck.. hope this helps
Old Nov 6, 2007 | 09:29 PM
mlcrycc's Avatar
mlcrycc
+1...[sm=icon_rtfm.gif]
That being said, here ya go....
http://www.mustangblog.com/info/2006.ownersmanual.pdf
Old Nov 6, 2007 | 09:37 PM
grampa_stang's Avatar
grampa_stang
There's instructions in the manual regarding headlight alignment and needing
to be 20 ft away from a wall and something or other. OR, just pull into your
garage and leave about 2-3 ft of space between the headlights and the garage
wall. Turn on the headlights and mark the wall with a pencil where the light hits.
Then use the screwdriver and start to turn the adjuster screw, you'll see the
light pattern move up/down, and then you'll know which way to turn the screw.
Old Nov 8, 2007 | 04:41 PM
07Mustang's Avatar
07Mustang
Thanks anyone
Old Nov 8, 2007 | 07:43 PM
Orion_240's Avatar
Orion_240
park 25 feet from a wall and then...
here's the rest:
[IMG]local://upfiles/15212/25476267C9E04351AE761EF2BDB76E8B.jpg[/IMG]
Old Nov 8, 2007 | 07:48 PM
MantaDreams's Avatar
MantaDreams
all cars headlights are directed just a wee bit to the right (just a wee bit). you should never have to adjust right or left anyways.
Old Nov 10, 2007 | 09:58 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Orion_240
here's the rest:
and now how high do the fogs need to be?
pdf on that?
MasterLanMan
21
Sep 16, 2015 03:26 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Blk Vert
Sep 9, 2015 12:16 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 04:12 PM
