2008 Hid lights
Old Nov 7, 2007 | 02:00 PM
schapman's Avatar
schapman
Default 2008 Hid lights
does anyone have any contacts at ford that could help me install the 2008 HID lights? I have the lights and found out there's a difference wiring harness ($60) for the lights. The problem I'm having is the low beam light wire needs to say active when the highbeam are switched on. My current harness/light coding turns the low beam wire off when the high beams are selected. I need to know if the new harness is all I need or is there some cpu chages to make it work?[/align]
Old Nov 7, 2007 | 02:29 PM
Autoengineer's Avatar
Autoengineer
Default RE: 2008 Hid lights
Isn't there a ballast required as well? I though HID lights require high voltage AC power so a ballast that converts the 12V battery to high voltage AC is required.
Old Nov 7, 2007 | 03:23 PM
torch red's Avatar
torch red
PLease keep us informed on the job..i so want the 08 lights...
How much did u pay for them and where..wish i could help with your problem..
good luck..
Old Nov 7, 2007 | 03:50 PM
schapman's Avatar
schapman
I paid $119for both headlight assemblies on Ebay including shipping.I can install them now witha $10 H13 wiring adapter but the highbeams wouldnt work. I really just need to know if its the new Ford harness or some type of cpu coding that actually keeps thelow beam wire active with the HIDswhen i switch to highbeams.
Old Nov 7, 2007 | 04:00 PM
torch red's Avatar
torch red
Oh..i thought you bought the 08 HID from Ford...they are now a option for the 08 Stang..
Old Nov 7, 2007 | 04:03 PM
schapman's Avatar
schapman
They are the08 HID from Ford but I got them on ebay.
Old Nov 7, 2007 | 04:07 PM
torch red's Avatar
torch red
Really...please provide the link..thank you..i will look now myself...
awesome keep us posted..
Old Nov 7, 2007 | 04:15 PM
schapman's Avatar
schapman
The seller said one of the lenses was blimished but I cant see it. he also sold another set for $300 before I purchase mine.
http://cgi.ebay.com/ebaymotors/ws/eB...69094&rd=1
Old Nov 8, 2007 | 07:59 AM
schapman's Avatar
schapman
bump
Old Nov 8, 2007 | 08:34 AM
TPony's Avatar
TPony
Wow, I just went to that link and was a bit surprise by the info the owner posted. Thinks like prototypes and no way to test them...not sure how made those, but the Ford ones are about $500+ each. Hope you can solve your problem.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
