Guage help please
if you can't find the mini add a fuse locally, you
can order it online from a few places....here's one
example
http://www.partsexpress.com/pe/pshow...mp;PID=1828117
example
Thank you!
Ok,soi'm just needing to splice into the headlight switch for illumination, will this also allow me to dim the guages?
And the mini add a fuse in the pic, is that one fuse per guage in that double fuse holderand what amp fuses?
BTW, thanks again hammeron
DISCLAIMER! follow the instructions
in that other thread exactly and you'll be ok.
the headlight splicing is just for the illumination
circuit and yes it is controlled by the dimmer
switch (that's what makes it cool)
i used a 5amp fuse for the add a circuit and ran
power to all 3 of my gauges.
This is what the fuse panel (passenger kick panel) will look like with the add a fuse installed....
Also, there is a nice ground screw right in front of the fuse panel, under the kick panel.....
[IMG]local://upfiles/13557/01AE6873FDD949348F5B1F412EE36CDE.jpg[/IMG]
[IMG]local://upfiles/13557/85414BF683824942AE0739A210367D0F.jpg[/IMG]
Dearborn5.0
Aug 9, 2004 10:42 AM
