HELP! Installing My HID's..
Old Nov 18, 2007 | 12:45 PM
v6VenoM's Avatar
v6VenoM
Default RE: HELP! Installing My HID's..
ORIGINAL: D_Gusler
ORIGINAL: schapman
does the wiring harness have a relay? All HID systems for the mustang have to be connected directly to a relay and that connected to the battery. You use your headlight wire to activate the relay/Hids.
Uhhhh, no they dont. The pilot kits i'm running do not have relays, and I have zero problems.
Are yours plug and play? A buddy of mine had wires going to the battery and had no problems. I am just wondering why they work with no problems when I hook them into the high beam on the connector. I turn my high beams on and they work. I am puzzled
Old Nov 18, 2007 | 12:49 PM
schapman's Avatar
schapman
with the information I have installing HID in the mustang you must have a relay or canceller in the harness. The SJB is looking for a 55W load and the HID's only use 35W. The SJB thinks the lights are not on.
Does thepilot kit connect directly to the mustang harness without extra wiring?
Old Nov 18, 2007 | 12:58 PM
v6VenoM's Avatar
v6VenoM
Yes directly to the pos and neg in the stock harness. It is straight plug and play. Do you have a solution? Do I need a higher amp fuse?
Old Nov 18, 2007 | 06:43 PM
v6VenoM's Avatar
v6VenoM
Ok so the place I bought them from, they are going to send me some special harness that I need because they said the car takes a 50w bulb where as the HID's are 35w so the harness will make the computer think that the HID's are a 50w and it should work after that.
Old Nov 18, 2007 | 07:37 PM
D_Gusler's Avatar
D_Gusler
No adaptors here, and it is a true plug & play kit. No extra wiring, etc.
Old Nov 18, 2007 | 07:50 PM
D_Gusler's Avatar
D_Gusler
Here's where the ballast is mounted, and as you can see, no extra wires running everywhere.
Old Dec 4, 2007 | 11:43 PM
zid3's Avatar
zid3
mike come to my damn house and ill do them for you lol o and the pilots have a resistor built in to them but they tend the blow after a couple of months(in install at least 8 pairs of hids a week, work in a car electronnics place,)
Old Dec 5, 2007 | 02:24 AM
olvanish's Avatar
olvanish
ORIGINAL: v6VenoM
I wonder if these people actually thought about that when they sent u this kit. Same thing Happened to me, when I was halfway done I realized that I was missing something and had to take the whole thing apart and wait for the correct relay to come in. Why is it that hard to do a little research about what kinda of car you as a dealer are selling these lights for?
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
