Headlight Question (Auto Lights)...
Old Nov 26, 2007 | 12:19 PM
v6VenoM's Avatar
v6VenoM
Default Headlight Question (Auto Lights)...
Ok so I have an 07 GT and when I use my keyless entry the headlights come on. Does anyone know of a way to disable that? I do not have a manual and I called Ford and they don't know, so I was hoping that someone here would know how to. Any help is appreciated, thanks.
Mike
Old Nov 27, 2007 | 05:01 PM
kdrshocker's Avatar
kdrshocker
Default RE: Headlight Question (Auto Lights)...
I think it's in the owners manuel. Could be wrong though... I'll go out to the garage and check for you.
Old Nov 27, 2007 | 05:21 PM
kdrshocker's Avatar
kdrshocker
Darn it.. i tried to scan it in and you can't read it...
You better appreciate this... I gotta type all this crap up....
"Enabling/disabling the permeter lighting feature:
...All vehicle doors must be closed before beginning the procedure. you must complete steps 1-2 within 30 seconds, or the procedure will have to be repeated.
1. Turn the ignition to the 3 (ON) position, then press the UNLOCK BUTTON on your keyless entry remote three times.
2. Turn the ignition to the 1 (OFF) position then press the UNLOCK BUTTON on your keyless entry remote three times.
3. Turn the ignition to the 3 (ON) position; the horn will chirp to indicate the driver configuration mode has been activated.
Activating or deactivating the perimeter lightingonce in program mode is accomplished by:
- pressing the trim panel power door unlock control twice within five seconds.
At this point, permeter lighting will be activated if it was previously deactivated, and deactivated if it was previously activated. Confirmation of perimeter lighting being activated is provided by a short horn chirp followed by a long horn sound; Confirmation of perimeter lighting being deactivated is provided by a short horn chirp only.
Exiting the program mode is accomplished by turning the ignition to any position other than the 3 (ON) position, or two minutes elapsing since the program mode was entered."
Quoted from a March 2007 Fourth Printing Owner's Guide Ford Mustang pages 80 and 81.
Gregz
Oct 18, 2022 03:52 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
CubanoGT
Oct 2, 2015 10:29 AM
kdryan
Aug 21, 2015 04:01 PM
inyadreems
Aug 21, 2015 09:10 AM
