Wheel question
Old Nov 26, 2007 | 12:57 PM
mightymouse's Avatar
mightymouse
Default Wheel question
Can someone tell me if a 17x10.5 rim with a 44mm offset work ok on the rear of my GT.. Does any one have pics of there car with them??
Old Nov 26, 2007 | 02:25 PM
drbobvs's Avatar
drbobvs
Default RE: Wheel question
That's cutting it close. You need to be sure you have at least7" backspace clearance. Measure from the plane of the rotor face to the shock and to the LCA. If it's at least 7", you're OK.
Old Nov 26, 2007 | 04:41 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: mightymouse
OK, 44mm offset, but whats the backspacing? [&:]
Old Nov 26, 2007 | 09:24 PM
Gene K's Avatar
Gene K
ORIGINAL: 157db
Wheel Width / 2 + Rim Lip Thickness + Offset = Backspace
10.5/2 + 0.5 + 1.73 = 7.48
So roughly 7.5" BS.
Old Nov 26, 2007 | 09:38 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
What the... since when do we do any kind of math on these forums. That hurt my head.
Old Nov 26, 2007 | 09:48 PM
FyouGitive's Avatar
FyouGitive
No pain, no gain.
Old Nov 26, 2007 | 09:59 PM
tungstenstang's Avatar
tungstenstang
im guessing the BS on the end of your equation stands for bull shyt, rim lip thickness? lol
Old Nov 27, 2007 | 08:36 AM
Gene K's Avatar
Gene K
ORIGINAL: tungstenstang
Quoted wheel width is bead to bead. Backspace is from the mounting surface to the OUTER Edge of the wheel.
Usually a 10.5" wheel is around 11.5" measured from extreme outer edges of the wheel lip (the portion of the wheel that protrudes outward to avoid cutting the tire).
Tivo304
Aug 28, 2023 12:19 PM
Luke9222
Oct 22, 2015 11:55 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
