Loud POP!
Old Nov 29, 2007 | 03:11 PM
GidyupGo's Avatar
GidyupGo
Default Loud POP!
OK, I had just rotated my tires here at the house, and went to the store. I do my shopping, and get back in the car and am wrestling with the seat belt. Before I even start the car, I hear a load pop or thunk noise from the left front. It sent shock waves down the driver's door. At first, I thought someone had hit me with a snowball. Then, I got to thinking, maybe the spring or the sway bar settled from it being off the ground. Maybe the spring was in a bind or something. Anybody???
Old Nov 29, 2007 | 03:46 PM
hammeron's Avatar
hammeron
Default RE: Loud POP!
did the tire fall off
Old Nov 29, 2007 | 03:52 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: hammeron
No. I checked and still had all 4 of em. I checked the lugs to make sure they were all seated correctly. I'm thinking springs. There is a plastic isolater in there and maybe it was pinched. Ihave heard of the sway bar becoming loose after the strut mount replacement but mine is nut busting tight.
Old Nov 29, 2007 | 04:04 PM
hammeron's Avatar
hammeron
interesting.....i've rotated my
tires and have had the fronts
off so many times, i've forgotten
how many.....i don't remember
any pops
not sure what happened to you
and maybe it wasn't even related
to the tire rotation
Old Nov 29, 2007 | 04:16 PM
alex0o85's Avatar
alex0o85
How do you rotate tires? Seriously, teach me!!! please?
drbobvs's Avatar
drbobvs
You spring popped back into the upper seat. It's happened to me too, VERY loud!
Old Nov 29, 2007 | 04:29 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: drbobvs
Thanks Doc. I can sleep tonight.
Old Nov 29, 2007 | 04:34 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: alex0o85
OK. I do a 4 tire rotation because the spare is a little dognut tire also known to me as a Gideon. I once knew some Gideons that were dirt poor like I was and they would get these things free and run em all the way around.
Jack up the driver's side rear. Take that tire off and put the Gideon on there. Take the tire that used to be on there and put it on the driver's side front. Take the one that was on the DS front and put it on the pass side rear.Take the one that used to be on the PS rear and put it on the PS front.Take the one that used to be on the PS front and put it on the DS rear where the Gideon is.
Old Nov 29, 2007 | 04:42 PM
ohnoesaz's Avatar
ohnoesaz
ORIGINAL: GidyupGo
ORIGINAL: alex0o85
I usually use two jacks on one side and jack it up and just swap the tires. Never involved a spare tire before....
Old Nov 29, 2007 | 04:43 PM
drbobvs's Avatar
drbobvs
+1
