Anti-Theft System
Old Mar 9, 2005 | 03:34 PM
algregory's Avatar
algregory
Default Anti-Theft System
Visited the dealer yesterday. I think my skipping Shaker 500 issue is gone. They were johnny on the spot.
I've been thinking my Anti-Theft system is not working. They agreed, couldn't give an answer right away, I had somewhere to be.
Little light flashes in dash. Keyless thing locks and unlocks doors. Trunk. Double hit on button makes flashers flash and horn honk. Unlock double hit unlocks two doors, but, the only sound is the doors unlocking. When you turn key to start car, the little red flasher in dash goes out, apparently signifying all is well.
However, the window/key trick to make them go down doesn't happen. Same goes for the remote. Shake, rattle and roll, jiggle handles, no signs/sounds of displeasure from the car.
Anybody else? Get it fixed already? What did they find?
Gregory
Old Mar 9, 2005 | 04:13 PM
96GTponyup's Avatar
96GTponyup
Default RE: Anti-Theft System
Mine is like that to! I have the abi-theft system on my car and I can double click the lock button, the horn honks but when I jiggle the door handle or shake the car nothing happens.
Old Mar 9, 2005 | 04:42 PM
lostsoul's Avatar
lostsoul
I thought that was normal for the reg alarm.. I think there an alarm option for 200+
Old Mar 9, 2005 | 05:20 PM
algregory's Avatar
algregory
I paid $225 for "Active Anti-Theft". It's on my window sticker.
Gregory
Old Mar 9, 2005 | 05:27 PM
05SatinSilver's Avatar
05SatinSilver
ORIGINAL: 96GTponyup
Nothing happens, because nothing is supposed to. If, you actually opened the door, Then it would alarm. Try this, leave your windows down. Set alarm, wait 30 seconds. Then, stick your arm inside the window and shake hand. ALARM... That's the motion sensors working for you. Or, set your alarm, then try to jack up the front or rear end. Alarm will go off again!
Dave...
Old Mar 9, 2005 | 06:04 PM
lostsoul's Avatar
lostsoul
Damn.. I should have done that too.. can you get the windows to come up to auto.. any control on those.. $225 is about normal alarms with those features.
Old Mar 9, 2005 | 07:12 PM
Scottsat's Avatar
Scottsat
Darn!!!!
that horn is loud,
per your description the system works like a charm!!!!!
Turn key to right and hold and both windows roll up!!!
I gotta tell you, this board is one GREAT resource!!
Thank you for sharing the knowledge and thank Ford for a fine Automobile.
Later,
Old Mar 9, 2005 | 08:46 PM
SpikeGT's Avatar
SpikeGT
I cant get my windows to go up? i know i have active anti theft, cause when the windows are down and i put my arm in the horn goes off? anyone else have the window problem?
Old Mar 9, 2005 | 11:32 PM
algregory's Avatar
algregory
For one reason or another I got the alarm to go off when I was waving my arms around inside the car. Still can't the the windows to roll up.
Think one thing is that you need to push the lock button twice, quickly, less than three seconds?
BY "turning the key to the right" I'm thinking you mean "clockwise"?
Gregory
Old Mar 9, 2005 | 11:54 PM
Scottsat's Avatar
Scottsat
Yes, clockwise......
Later,
[IMG]local://upfiles/13237/66C0D05661B04256BE7AAC282A1E0F50.jpg[/IMG]
[IMG]local://upfiles/13237/577F6F1B204B4B82A523E372464CCC88.jpg[/IMG]
