Sponsored by:
Sponsored by:
How does adding CAI/tune make exhaust sound better?
Old 12-20-2007, 10:34 PM
Burnsy
Burnsy's Avatar
Default RE: How does adding CAI/tune make exhaust sound better?
ORIGINAL: thewarmachine
Isn't it obvious...... when a new tune is installed the little man who sits in the H of the H-pipe and beats on his little drum to make the sound gets more air to breathe and can therefore make better drumbeats. When an X-pipe is installed, there is no comfortable place for the little man to sit. Hence he gets blown out the rear, and the only thing left to hear is the empty Chef Boyardee cans he left tied up in little trash bags hanging in the cross of the X.
= greatest exhaust explanation I have ever read & pwns all
Burnsy is offline
Old 12-20-2007, 10:49 PM
thewarmachine
thewarmachine's Avatar
Aren't you glad you have access to my dementia?
thewarmachine is offline
Old 12-21-2007, 12:04 AM
AmericanMuscle4.6GT
AmericanMuscle4.6GT's Avatar
you will notice the difference mostly at WOT, when the tune has the most difference.
also, the tune changes timing and such, and the car will sound a little different, if you really think you have the ear for that.
but most of the noise from a big open intake, comes from the intake itself, the actual induction noise. ford puts a lot of money (well some at least) into quieting the stock intake, and an open intake is basically a direct path at WOT through the intake manifold all the way down to the heads, so that noise is projected better through the aftermarket intake, plus your sucking more air in and the actual noise the intake itself makes.
AmericanMuscle4.6GT is offline
Old 12-21-2007, 01:56 AM
GT Bob
GT Bob's Avatar
ORIGINAL: 300GT
ORIGINAL: GT Bob
Actually, most tunes lean out the fuel, making LESS unburnt fuel in the exhaust... The S197 is ridiculously rich from the factory. In fact, alot of tunes also disable alot of the cars ability to dump in extra fuel at WOT to cool the cats and exhaust manifolds.
It boils down to (as was already stated) simply more air in and more air out.
If most aftermarket tunes are leaner than the factory tune, then why is it that most people that I know that have aftermarket tunes have lots of black residue on/around exhaust tips, whereas I (with stock tune) have no black residue. I would think it would be the other way around. Please elaborate. Thanks.
From the factory, the computer commands a 12.44 AFR up until 3000 rpms, from there it gets even richer to a 12.0. Getting richer on the top end is the exact opposite of what you want to have happen. The combustion event has less time to completely combust the fuel in the charge, so it needs to get leaner up top so that the entire fuel charge can burn. The factory adds this fuelas a protective measure. It also has a few other protective measures that add fuel at WOT as well as clean up the emissions.
To get power out of these cars, the fuel needs to be leaned out to the 12.8-13.0 range, and as an added measure most diasble most of those emissions fuel adders as well. The black carbon is likely from disabling the emissions and overtemp controls. It's much more pronounced with canned tunes than it is from mail order tunes. Canned tunes tend to run richer due to the fact that they have to able to be used on a far wider range of cars, while the mail orders can get it closer, but they still aren't exact.
GT Bob is offline
msavoia23
12
07-07-2018 12:08 PM
drfister
05-03-2018 10:38 PM
Barcafut13
09-01-2015 06:08 AM
Goldenpony
08-19-2015 08:46 PM
08-18-2015 03:39 PM
Quick Reply: How does adding CAI/tune make exhaust sound better?
