Engine Overheating? *FIXED* maybe
Old Jan 2, 2008 | 01:28 PM
harraid5711's Avatar
harraid5711
Default Engine Overheating? *FIXED* maybe
So this moring, i drove home from my gf's apartment......approx 3 min drive time, barely enough time to get warmed up all the way being that it was 33 or 34 degrees out. My car stayed parked for almost 2 hrs while i was getting ready for work, should have cooled all the way off right?? Anyways, when i started it, the temp gauge already was right in the middle.....kinda thought that was odd. when i started driving, it started creeping up until i pulled over because i thought i was overheating. by the time i got back, it was pegged, but no check engine lights, or warnings, codes, or limp-home mode or anything. i still had coolant, and the engine heads were touchable, and it didn't seem or "smell" hot. i drove another car to work just to be sure, but what do you think?? i'm gonna go test it again later, but i'm not sure if it's a false reading or what. anyone heard of a gauge acting like this? it's not like it was stuck, but it was wavering back and forth when i turned my keys off and on......
btw, my gas gauge and radio have acted up when it's really cold like it was this morning, can my temp gauge do the same thing?? i'm gonna check the oil for fluid later, what will it look like? also, i will check my fan......
any help??
disconnected the battery, reset the pcm......seems to be fixed for now!! i'll keep my eye on it
Old Jan 2, 2008 | 01:36 PM
owero01's Avatar
owero01
Default RE: Engine Overheating?
Never experienced that. You may need to reset everything by disconnecting the battery and reconnecting.
Old Jan 2, 2008 | 03:05 PM
imyy4u's Avatar
imyy4u
that's weird...most likely a guage malfunction, because if you were overheating, you'd know it. sure your belt didn't snap? or something didn't stick? i had that happen on my last car and it caused the car to overheat even though everything seemed normal...
good luck.
Nick Oliver
Oct 17, 2018 04:22 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
