Sponsored by:
Sponsored by:
How to hard wire a Cobra Radar Detector.
Old 03-07-2008, 06:44 AM
whtcanbrwnd04u
whtcanbrwnd04u's Avatar
Default RE: How to hard wire a Cobra Radar Detector.
I payed a stereo shop $40
whtcanbrwnd04u is offline
Old 03-07-2008, 07:28 AM
Speedyejl
Speedyejl's Avatar
I'm not sure about Cobra's but Passports use a standarad telephone cord for power. The inner two wires if I remember correctly are used for power/ground.
I ran it above the windshield down the passanager A pillar to the fuse box, tapped the compass/mirror fuse since its switched.
The phone cord was essentially free, it took 5 minutes.
Speedyejl is offline
Old 03-07-2008, 09:34 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: steveo555
inside the arm rest storage compartment and plugged it into the 12v outlet. When the car turns on it goes on and when you remove the keys it stays on until someone opens a door.
I didnt know the arm rest power outlet was switched off with the accessorry delay.
I will have to look this up in the 07Ford workshop manual to see how its done.
157dB is offline
Old 03-07-2008, 10:55 AM
MustangBatman1
MustangBatman1's Avatar
How ironic, I was planning on hardwiring the cobra radar I just bought today. Thanks for the info.
MustangBatman1 is offline
Old 03-10-2008, 09:38 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: steveo555
I wired my radar detector from the mirror to the 12v outlet in the center counsel, I tucked the wire up into the headliner then through the a-arm and down under the dash. Zip tied it under the dash and into the center counsel and through the access panel inside the arm rest storage compartment and plugged it into the 12v outlet. When the car turns on it goes on and when you remove the keys it stays on until someone opens a door. I think this way is easier then hardwiring it to the fuse box or map lights.
Here is a pic from the 07 workshop manual showing HOT ALL THE TIME
for both power outlets. You must have the newfangled 08 model?
[IMG]local://upfiles/69445/A045A7098EB54819BD8C45BE4820C8FF.jpg[/IMG]
157dB is offline
Old 03-10-2008, 09:51 AM
ajaibr
ajaibr's Avatar
my 07 power outlets are always on.... i went for a switched fuse and used one of those add a fuse thingies from the auto parts store....
ajaibr is offline
Old 03-10-2008, 05:26 PM
MustangBatman1
just hardwired mine today, I'm amazed at how easy it was!
Old 03-11-2008, 05:11 AM
str8wick3d
str8wick3d's Avatar
Hardwired my radar detector to my windshield wiper fuse with a
http://www.gizmos-gadgets.com/index....783a620c24d6d2
So easy, and such a clean install. Radar comes on when car starts, and goes off when car shuts off.
str8wick3d is offline
Old 03-11-2008, 08:43 AM
157dB
Cut & Paste Expert
157dB's Avatar
Use fuse #7 location in the SJB.
157dB is offline
11-10-2015 11:39 AM
TheDutchTexan
Mustang Videos
09-10-2015 06:51 PM
Sparks_88
09-08-2015 01:06 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: How to hard wire a Cobra Radar Detector.
