17x9 wheel help!
Old Jan 12, 2008 | 08:39 AM
ckone0814's Avatar
ckone0814
Default 17x9 wheel help!
I've asked before but just want to confirm...
I have an 07 GT. I got a set of chrome bullitts of of Ebay from ACS Wheels for a good $. They are 36mm offset. I am looking to put 255/50 tires on them. My local shop is searching for tires for me - they've gotten good prices for me before, I get free rotations, stems, etc. - basically, I'd like to buy tires through them if I can.
They are telling me this set-up may rub, you won't like them, this is all not stock, etc, etc. Basically, anything that's not stock they push back on.
Will this set-up functionally be ok? Will it look ok? My understanding is that the wheel/tire will stick out just slightly more than 1/2 inch from stock. Is that right? If so, I think that will look fine, and maybe even better?
Thanks again.
Old Jan 12, 2008 | 09:14 AM
Norm Peterson's Avatar
Norm Peterson
Default RE: 17x9 wheel help!
I think they will be about 0.8" or 0.9" more on the outside. 17 x 8's are about 9.2" overall width with 45mm offset and 6.3" backspacing. Half an inch from the extra width and about 0.4" from the difference in offset. Effectively, most of the width increase was put on the front side.
With about 10.2" overall width, the 3.7" front side distance with those 17 x 9's is only 0.1" more than what's on the GT500 wheels (18 x 9.5, 45mm offset, 7.13" backspacing, about 10.7" overall width, 3.6-ish front side). Should be OK.
I have a spreadsheet that does all this math, just not on this computer (yet), so you might want to check the math. The above dimensions are per the current FRPP catalog.
Norm
Old Jan 12, 2008 | 10:37 AM
ckone0814's Avatar
ckone0814
ORIGINAL: Norm Peterson
Thanks. I thought oem 17 wheels are 17x8.5?
Old Jan 12, 2008 | 10:45 AM
Black05StangGT's Avatar
Black05StangGT
OEM rims are 17.8"...I have some bullit wheels that are 17x9" but my offset is +42...which is the correct offset for the 05-08 mustangs for the rear at least...also I am running 275/40/17's with no rubbing issues at all...and the car is lowered 2" in the rear...
Old Jan 12, 2008 | 11:52 AM
DarkFireGT's Avatar
DarkFireGT
American Muscle sells 17x9 Bullitts with a 45mm offset for the 2005+, but they also sell Mach 1's in a 36mm offset, again for the 2005+. You should be fine as long as they said they were for 2005+. AFS and American Muscle are pretty good about that.
Old Jan 12, 2008 | 01:30 PM
ckone0814's Avatar
ckone0814
.8 or .9? Looking at my car now and figuring on another almost one inch sticking out (especially the front) - that concerns me.
Old Jan 13, 2008 | 10:13 AM
Norm Peterson
That has to be the measurement to the outer diameter and sounds about right for a 17" wheel. The nominal wheel size - both the diameter and the width - is measured to the bead seat on the inside of the rim.
ck - Go look at a GT500. And see post #2 above.
Norm
Old Jan 13, 2008 | 06:49 PM
EricM's Avatar
EricM
ORIGINAL: ckone0814
It will be fine. I have 30mm offset 9 inch wide on the front. They don't stick out of the fenders with 275 tires - they're actually still tucked in a bit.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
