Next most important gauge
Old Jan 21, 2008 | 05:10 PM
breathegood's Avatar
breathegood
Default RE: Next most important gauge
It is a daily driver. Only thing it will be hauling is @ss. My experience is with Toyota 4x4 pickups and SUV's so the trackwill be a new experience for me, but I will get on the track as soon as summer weather permits.
I've seen comments on other forums about an EGT (Pyrometer)being a pretty useful gauge for tuning purposes. It should be a pretty good indicator of whethertiming and fuel are within a safe margin of error. Too lean or too much timing, and youshould seethe result on an EGT gauge.
Old Jan 21, 2008 | 05:18 PM
Dex's Avatar
Dex
Diesels need them because they're always in boost and when hauling heavy things youre going to be running a constant 15-20lbs of boost.
So for a DD car and half track car IMO you dont need a EGT gauge
Old Jan 21, 2008 | 05:20 PM
modaddict's Avatar
modaddict
Heat = #1 bad for your motor
Especially with a turbo, monitoring heat is the primary concern IMO...
After the pyrometer, I would do oil temp and fuel pressure.
Old Jan 22, 2008 | 10:21 AM
breathegood
ORIGINAL: modaddict
So, where would you mount the EGT probe, and what are safe EGT's for a 4.6l 3v?
Old Jan 22, 2008 | 11:27 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
inquiring minds want to know!
Old Feb 2, 2008 | 02:14 PM
Stangula's Avatar
Stangula
If you are gonna be hot lapping an EGT is Good for daily driver i would rather monitor fuel psi
Old Feb 2, 2008 | 02:16 PM
Stangula's Avatar
Stangula
but i gues you already have Air fuel so EGT is good
Old Feb 2, 2008 | 03:51 PM
Stkjock's Avatar
Stkjock
Retired Mod
get an aeroforce scan gauge.... read both IAT and Coolant (or 40 other things) at the same time
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
