HELP!! Throwing codes...running lean
Old Feb 27, 2008 | 01:36 PM
notsotipykal's Avatar
notsotipykal
Default HELP!! Throwing codes...running lean
Hey guys...I installed a C&L Intake and tuner when I had 1/4 tank of 87 octane. Filled up with 93 AFTER I set the tune for 93 and just threw 3 codes...They are as follows:
P0171
P0174
P1000
I re-installed the 87 octane tune and the CEL went away. But that doens't mean the CEL WON'T come back on. Why am I running lean? (Thats the the first 2 codes said ..not sure about what the third one was)
Mat
Old Feb 27, 2008 | 01:45 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: HELP!! Throwing codes...running lean
same codes you get when you put a catless midpipe on, turn off the rear O2s will get rid of the codes, but if you do not have a midpipe then that is odd
Old Feb 27, 2008 | 01:48 PM
notsotipykal
I'm going to be putting on my Pypes H pipe in about 2 hours, other than that, I just installed the intake and tune. Could it have anything to do w/ the sensor that plugs into the neck of the C&L (same one that we disconnect from the stock intake) being loose? It was just a HAIR loose and I just pushed it back in and the light went away when I turned the car on. Didn't even "clear codes" w/ the Tuner.
Old Feb 27, 2008 | 02:28 PM
notsotipykal
ttt
Old Feb 27, 2008 | 02:38 PM
GidyupGo's Avatar
GidyupGo
Your octane wasn't high enough.
Old Feb 27, 2008 | 02:45 PM
notsotipykal
so, when can i re-tune the car back to 93 octane? when im about half way through my tank and refill the rest w/ 93? or should i wait til im runnin on E and then refuel entirely w/ 93 octane?
Old Feb 27, 2008 | 02:53 PM
rshamekh's Avatar
rshamekh
After you run your tank empty and fill it with 93 AGAIN, then you can use the 93 tune. It won't hurt to install the 93 tune now if you're not gonna go WOT!
Check the MAF sensor, and where the intake connects to the throttle body, it might not be tight enough.
Old Feb 27, 2008 | 03:02 PM
notsotipykal
ok will do..im havin a buddy that works for FORD install my H pipe around 5...so after that gets installed i'll make sure everything is tight...thanks guys....keep the info coming too..ill be checking this site ALL DAY
mat
Old Feb 27, 2008 | 03:06 PM
rshamekh's Avatar
rshamekh
You're going to love the Pypes H. Is that with stock mufflers?
Old Feb 27, 2008 | 03:14 PM
GidyupGo's Avatar
GidyupGo
You were at about 91.5 octane before. If you refill now at half a tank with 93, you will be close enough. Your mistake was tuning it with 87 in the tank, then driving it to the station to fill it up. You need to get your fuel right before you tune it.
