Help!! Instrument cluster went out while installing a tune!
Old Mar 13, 2008 | 09:09 AM
jkcstang's Avatar
jkcstang
Default Help!! Instrument cluster went out while installing a tune!
I tried to install my tune and while doing this the tuner shut off and my whole instrument cluster died. Gauges dont work, lights dont come on, turn signals dont work, etc. Anyone know what happened? Did it blow a fuse or is this a serious problem. I havent been able to check the fuse yet(at work).. Any help would be appreciated!!
Thanks
Old Mar 13, 2008 | 09:11 AM
moosestang's Avatar
moosestang
Default RE: Help!! Instrument cluster went out while installing a tune!
Did the tune finish loading? Sounds like a blown fuse.
Old Mar 13, 2008 | 09:12 AM
Sleeper05's Avatar
Sleeper05
You blew a fuse. Check the box under the hood on the passenger side, then check the box inside behind the passenger side kick panel.
Old Mar 13, 2008 | 09:23 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=40&viewfile...nformation.pdf
http://iihs.net/fsm/?dir=40&viewfile...%20Cluster.pdf
http://iihs.net/fsm/?dir=40&viewfile...ns%Network.pdf
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
5.0pntydrpr
Aug 27, 2015 10:26 PM
'stangdude
Aug 12, 2015 01:27 PM
