JLT CAI arrived
that is pretty sweet. Have you seen behind the hood insulation yet? There is actually a place marked off in the hood about the size of that shaker scoop. Almost like it was intended for it.
Why not do a little DIY on the pipe work and combine the shaker scoop with the CAI. Steeda and C&L both have setups that seal against the hood basically creating an airbox. Don't see why this could not be modified to pipe air into that space.
ORIGINAL: GWFoos
Got the box when I got home. 4"x9" cone filter, perfectly matched windveil blue piping, directions with pictures.
I can't put this in until I get the xcal, right?
with that new shaker hood i wonder if there is a seprate program needed just for it or if you can use same tune as a CIA? i will probubly get this ram air system as well just wonder if the steeda tune i have will work or if cdc will come out with a tune of their own.
junior04
Sep 28, 2015 10:53 AM
