Help Wiring Shift Light
Old Mar 14, 2008 | 03:40 PM
MustangBatman1's Avatar
MustangBatman1
Default Help Wiring Shift Light
So I bought ashift light with a digital tach but I seem to be having a problem wiring it. I wired the green wire to the coil pack on the drivers side closest to the rear (white with red stripe wire). Then I wired the red wire to a power source and the black one to a ground. My problem is that when I start the car the rpm's on the digital tach keep bouncing around between 100 and 300 rpms. I set the shift light and everything but the RPM's are way off and the car is idling just fine. The RPM's dont even follow the car when I rev. Anyone have any idea what the problem could be?
Neal
Old Mar 14, 2008 | 03:51 PM
ajaibr's Avatar
ajaibr
Default RE: Help Wiring Shift Light
You need a tach adapter.. .I used an Autometer 9117... They have Mustang specific instructions on their website... Gets wired into the backside of the fusebox under the hood and gives a tach signal that will work...
Old Mar 14, 2008 | 04:16 PM
157dB's Avatar
157dB
Cut & Paste Expert
So what brand of tach/shift light?
Old Mar 14, 2008 | 05:36 PM
S19706's Avatar
S19706
ORIGINAL: ajaibr
+1 http://www.autometer.com/download_instruction/561.pdf
2007StangV6
Jan 28, 2016 06:09 PM
zachary1988
Sep 4, 2015 03:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
