Old Oct 23, 2015, 03:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Tire Repair and Maintenance
Print Wikipost
Wheel Spacers---installed
Old Mar 22, 2008 | 08:16 PM
thewarmachine's Avatar
thewarmachine
Default RE: Wheel Spacers---installed
ORIGINAL: Legion5
ORIGINAL: thewarmachine
Take some 3/4 pictures of your car, don't be artistic. It's difficult to tell just by side photos as there is no third dimension to them, it's a profile.
I'll get some better pics when it's all done and my car is cleaner. I was just trying to get some pics from the front and rear so you can see the decrease in fender overhang.
Old Mar 22, 2008 | 08:23 PM
thewarmachine
ORIGINAL: tripc
The Fronts are a pain in the *** if you dont have air tools.. Dont take them all off because you wont have anything to hold on to when you tighten them....... I found out the hard way on the drivers side.. The passenger side were easy beacuse I used my air tools.. That was a breeze...
GOOD LUCK
Thanks, but I don't have air tools. I think the 2x4 wedged between two studs and the ground will work. I'm going to do the studs one at a time just like I did the rear.
Another idea is to lower the jack so that two bottom studs are resting on a block of wood and part of the car's weight can hold the hub in position.
Old Mar 22, 2008 | 08:48 PM
one eyed willy's Avatar
one eyed willy
do our rotors not have the vents on the edge of the rotor?most front rotors have these vents,i just use a long flathead screwdriver and put it in the vent and rotate the rotor until it makes contact with the claiper,that keeps it from moving any where.
these are the vents im talking about
Old Mar 22, 2008 | 09:04 PM
thewarmachine
You have to remove the calipers and rotors to install the studs.
Old Mar 22, 2008 | 09:07 PM
one eyed willy
oh,ok.
on my camaro,i just had to hit the stud with hammer to knock them out,then put the new one in from behind,then put a nut on it and tighten it down to pull the stud up into the new rotor,it was a real piece of cake.
Old Mar 22, 2008 | 09:09 PM
deekum1627's Avatar
deekum1627
looks good
Old Mar 22, 2008 | 09:30 PM
ohnoesaz's Avatar
ohnoesaz
Yuuuuuummmmmmmmmmmmmmmmmmmmmmmm. Better look and should be better handling too. I've always had a problem with how tucked in mustang wheels are....
Old Mar 22, 2008 | 09:31 PM
thewarmachine
ORIGINAL: one eyed *****
oh,ok.
That may actually work. The kit came with a stud removal tool that can't be used with the rotor on, but once the studs are out, you can replace the rotor and caliper and use the installation nut to seat the new studs. I'll have to try that!
Thanks, man!
Old Mar 22, 2008 | 09:42 PM
thewarmachine
ORIGINAL: ohnoesaz
Haha! Thanks. Yeah, I was surprised how much the Roush front springs/struts improved the handling. I'm anxious to see the difference the wider front will make. I'm also expecting a little more steering vibration since the tires are moving farther away from the steering pivots. ...but such is the price of fame.
Old Mar 22, 2008 | 09:57 PM
one eyed willy
oh,ok.
Thanks, man!
cool,give it a try,i used a washer between the nut and the rotor to make less friction.
