Last edit by: IB Advertising
Browse all: Ford Mustang Tire Repair and Maintenance
- Ford Mustang V6 1994-2014: How to Install Wheel Spacers
Step by step instructions for do-it-yourself repairs.
Wheel Spacers---installed
I finally got around to installing my wheel spacers....well....half of them. I did the rear this afternoon. I got "The Works 5/8 in" kit from www.mustangwheelspacers.com http://www.mustangwheelspacers.com/i...&ProdID=34
I am running 18x8.5 (50mm offset) silver bullitts with 255/45/18 all around. The spacers made a huge difference in the looks of the wheels. Finally got rid of the extremely tucked-in look....in the rear. I plan to do the front on Monday or Tuesday depending on the weather (no garage [&o] ).
Here are some pics.
Before (front)
After (front)
Before (rear)
After (rear)
Before
After
More After
The installation of the rear wheel studs and spacers was a breeze (thanks to WD-40
), but I'm wondering how I'm going to get the front studs on. I'm going to have to find a way to keep the hub from spinning while I tighten the stud installation nut to get them seated. I guess I can use a short 2x4 to wedge between two existing studs and the ground. I'll figure that out on Monday or whenever I get to it.
The rear brakes were a breeze to remove. Just loosen two bolts and slide the caliper off the rotor. I'm hoping the front is just as easy.
Using the 5/8" spacer is equivalent to adding a negative 16mm to the offset, so I'm now running about 34mm of offset on my bullitts.
I like the new look!
Also, here's a little video I made after I was done. The weird sound when I'm shifting to second in the first run is the rev limiter catching me just as I'm shifting. Oops!
http://s229.photobucket.com/albums/e...t=DSCN1171.flv
Here are some pics.
Before (front)
After (front)
Before (rear)
After (rear)
Before
After
More After
), but I'm wondering how I'm going to get the front studs on. I'm going to have to find a way to keep the hub from spinning while I tighten the stud installation nut to get them seated. I guess I can use a short 2x4 to wedge between two existing studs and the ground. I'll figure that out on Monday or whenever I get to it. The rear brakes were a breeze to remove. Just loosen two bolts and slide the caliper off the rotor. I'm hoping the front is just as easy.
The stance in the rear is much better! The fronts should not be too hard and post up the after pics when you get them installed. Congrats....looks much better IMO.... J
ORIGINAL: Stoenr
like the look!, now maybe some 255/45's when you burn those up!
Actually I'm thinking 275/45 when these are worn out.
The Fronts are a pain in the *** if you dont have air tools.. Dont take them all off because you wont have anything to hold on to when you tighten them....... I found out the hard way on the drivers side.. The passenger side were easy beacuse I used my air tools.. That was a breeze...
GOOD LUCK
GOOD LUCK
ORIGINAL: thewarmachine
They ARE 255/45's! I don't know why, but they always look skinnier with my camera.
ORIGINAL: Stoenr
I would go with a 275/45 on th 8.5" but thats just me.
ORIGINAL: Stoenr
I know, my 285/40's look skinnier in pics.
ORIGINAL: Stoenr
