Wheel Specs: Bolt Pattern & Offset
Old Mar 28, 2008 | 01:05 PM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
Default RE: Wheel Specs: Bolt Pattern & Offset
ORIGINAL: SlideWRX
The hub diameter may not be correct. Mustang hub is 70.6mm. If it's smaller than that, the wheel won't bolt up flat to the face of the hub. if it's larger than that, it will bolt up, but hub rings should be used to keep it centered. I happen to have summer wheels with 73mm hub, and torquing them down in the proper star pattern keeps it vibration free.
Tom
edit: The stock 17x8 wheels are 45mm offset. The V6 16x7 are 39mm offset. Generally, one could run 25mm offset on an 8" wheel without it sticking out.
Manufacturer lists hub at 73.1
Tivo304
Aug 28, 2023 12:19 PM
maestro1024
Sep 21, 2015 02:40 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Sep 8, 2015 11:50 AM
