Ford HIDs?
There only plug and play with steeda's harness. if you purchase them from ford you will need to buy a new ford harness or slice them in with 2 relays. 1 for low beam and 1 for high beam.
ORIGINAL: 157db
Looks like it.
http://www.steeda.com/directions/162...steeda_hid.pdf
ORIGINAL: ThumperMX113
Are they just a plug n play?
Can somebody tell me whay the saleen HID's are better then the Mustangs? And why there is a huge difference between in price. Also i saw a GT500 with them. Does anybody know the quality that those are going to.
ORIGINAL: Mr.Bape
Dang $995.95?? That's the same price as the Saleen HIDs! I was hoping to pay the option price which is $535.95
Are there any significant differences between these and the Saleens?
ORIGINAL: schapman
Saleens us the older D2R bulbs while Ford used the newD3R
The difference between D1r, D2r & D3r is that the bulb glimmers less... this not nessesarily desirable. This glimmer is determined by the bulb's core.
A bigger part of the picture is which generation of HID technology a system uses, or what's actually ignited. using a match vs a lighter to start a fire isn't as important as using gunpowder or paper to light... Ford for example uses the older generation 2 HIDs which last a shorter time, are less white, and take more energy to run as well as have a longer startup, while Saleen uses generation 3 HIDs. Generation 3 HIDs contain more burning stuff, ie Xenon gas.
ORIGINAL: GTStang07
Gt500 lights are the same as GT lights besides the housing.
Whats misleading about it? D3R are the newest type of bulbs...I didnt say it was better or worse.
"Ford for example uses the older generation 2 HIDs which last a shorter time, are less white, and take more energy to run"
Not sure were your pulling that out of. Ford used the d3rthat is the newest type of system. read link and text below.
What are D3S and D4S type HID bulbs?
D3x and D4x are mercury free versions of the D1x and D2x light sources. They do not work with older D1x/D2x type ballasts because steady on voltage is only 36 V. Compare that to a D1x/D2x style, and u will see that voltage is 85 V. In detail, 42 +/- 9 V can be measured at a D3x/D4x bulb. They have same output, same life as D1x/D2x bulbs
http://faqlight.carpassion.info/hl-hid-bulbs.htm
ORIGINAL: Legion5
No that's missleading, the igniter is just PART of the bulb and is not visible.
ORIGINAL: schapman
"There isn't a huge difference in price, if anything they are the same price. The Saleen HIDs look better, use better lighting technology, have a more attractive beam color, and accept aftermarket bulbs"
So you're saying that the saleen ones are better than the ones Ford are using now? And regarding more attractive beam color, what do you mean? Because I know the difference in lighting depends on the heat of the Kelvar: 4500k being white to 12000k being purple. Or something like that.
