FAST help please - electrical
Old Apr 20, 2008 | 10:14 AM
exx1976's Avatar
exx1976
Default FAST help please - electrical
Hey guys.. For those of you who were following my charging problems with the Saleen, I found the problem. The 4 ga wire that feeds the battery from the alternator worked its way loose on the post and it was arcing. So I need a new wire, it's COOKED. I'm gonna go over to the local stereo shop and have them whip one up, but I need to know something - there'sa fusible link in that wire. I need to know what it's rated at so I can put an in-line fuse in there to take it's place.
Please, the faster the help, the better, I need to put the car back together and get home. I'm at a buddy's house right now.
Thanks guys!!
Old Apr 20, 2008 | 10:29 AM
Black GT's Avatar
Black GT
Default RE: FAST help please - electrical
What's the rating of the fuse in the existing fuse link? The new link has to be at minimum the same rating. Or you could go with a higher rated fuse link as long as its designed for 4 gauge wire and you use the same rating fuse as the old one had.
Mtech9's Avatar
Mtech9
Ford uses 200 amp fuses for main power connection. If you can't get 200 amp fusable link there is a 200 amp maxi fuse available
Old Apr 20, 2008 | 10:33 AM
exx1976's Avatar
exx1976
Thanks!!!
Bokeo
Oct 10, 2015 08:28 PM
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
allenmaty
Sep 24, 2015 09:17 AM
TfcCDR
Sep 14, 2015 12:08 PM
