Gauge install...???
Old Apr 21, 2008 | 01:07 PM
HtownNick's Avatar
HtownNick
Default Gauge install...???
Hey guys, I'm wanting to know where you are wiring in your A/F Ration gauge? (narrow band) On my 4V I wired it into the O2 sensor. But on these new cars I'm not sure if that will work. I say that because I put an O/R x-pipe on one and the CES light never came on, with no mil's.
Also going to be installing a boost gauge and a mech oil pressure gauge.
Thanks in advance.
Nick
Old Apr 21, 2008 | 01:41 PM
SCCAGT's Avatar
SCCAGT
Default RE: Gauge install...???
Wideband gauges come with O2 sensors. Narrow bands are worthless to even come close to accurately measure A/F. So you make a new hole close to the manifold/header on one side, weld a bung to it and screw in the sensor. The wiring can go through the firewall behind the fender splash shield where the big harness goes through.
You cant put a sensor in the X. One side will suffice for A/F ratio unless you want to buy 2 sets.
Old Apr 21, 2008 | 03:31 PM
157dB's Avatar
157dB
Cut & Paste Expert
+1
widebands rock
it needs its
own sensor
and bung
Old Apr 21, 2008 | 07:40 PM
HtownNick's Avatar
HtownNick
I know wide bands are the best. This is for a friend of mine and is for show.He doesn't want to spend the money on a wide band.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
