Abusing your car..
Old Apr 30, 2008 | 06:10 PM
  #51
SlinkyBMX's Avatar
SlinkyBMX
Default RE: Abusing your car..
ORIGINAL: jahudso2
Wow Slinky, what kind of motor do you have that spins 5,500K? Did you swap a jet engine in that baby? I take it up to 6k every once and a while but never above 3k or more than 1/4 throttle when its not at full operating temperature.
Right out of a Boeing 747 .....whoops lol
Old Apr 30, 2008 | 06:52 PM
  #52
PennState's Avatar
PennState
my car was born to be abused..
Old May 1, 2008 | 07:25 AM
  #53
06VistaBlueGT's Avatar
06VistaBlueGT
ORIGINAL: 157db
ORIGINAL: 06VistaBlueGT
ORIGINAL: 157db
I have already had to replace my Raptor shift light
as all of the LEDs finally burned out from use. [&:]
And I have it set at 5300 RPMs.
Shetakes what I give her. Hopeshe holds up
for the time I haveher until selling for another.
5300?
Mine is set at 6200! No wonder yours is burning out!
I have a V6. It rev limits at 5750?
My MSD DashHawk's shift indicator is set just
below the stock rev limiter. The Raptor is kind
of a pre-shift indicator. It works well that way.
The DashHawk is a visualAND an audiable warning.
[IMG]local://upfiles/69445/164AF525897C4A52B50F20FCE4A2DC8A.jpg[/IMG]
Sorry bout that, it's doesn't say anything about V6 in your sig...
Old May 1, 2008 | 07:37 AM
  #54
Daniel60's Avatar
Daniel60
When I owned her in the first year or two, I did hit limp-mode several times but that was the result of shifting like a wild man from 5th to 3rd and so on. I know from experience that it's better to leave off the traction control because the son-of-a-bitch will interupt your fun with all it's traction control. Now with my 4:10 gears I only downshift from 5th to 4th for immediate barn burning and sometimes that isn't really necessary with all the gear I'm pulling. As far as the rpm factor , I still light it up occasionally but thanks to the gas prices I'm obeying the law more and more each day.
Old May 1, 2008 | 08:00 AM
  #55
chain1's Avatar
chain1
You were putting it into limp mode by shifting from 5 to 3? Were you over revving it? That's impressive (not in a good way!)
Old May 1, 2008 | 08:04 AM
  #56
Daniel60's Avatar
Daniel60
yes driving it like a jockey slaps the horse on the ***. Yes over revving it, your correct sir.
Old May 2, 2008 | 09:39 AM
  #57
VistaGT's Avatar
VistaGT
Brenspeed has my rev limiter set at 6800! Way too high IMO (probably most people's)
Old May 2, 2008 | 12:27 PM
  #58
Riptide's Avatar
Riptide
Is this setting something that is user adjustable with an XCAl 2?
Old May 2, 2008 | 01:34 PM
  #59
wmtheflash's Avatar
wmtheflash
ORIGINAL: Riptide
Yes, it is. SCT had my limiter set above the stock 6250 rpm limit. It adjusts in increments of 100 rpm, so I had to choose between 6200 rpm or 6300 rpm. I chose 6200 rpm.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Itzjoe
Aug 26, 2015 08:15 PM
antipeterleague
Aug 18, 2015 01:50 PM
