Suspension Help
ORIGINAL: Fullsayl
simplexdesign,
I don't know about the sticky (there is this one https://mustangforums.com/m_934501/tm.htm, but it is specifically related to lowering your car and is 14+ pages). Now you might try checking out this thread (https://mustangforums.com/m_4943892/tm.htm) for general info, look for the posts by F1fan, Rodeoflyer, Norm Peterson, and Sam Strano (they are kind of the resident suspension guru's over there). If you can't find your answer in that thread, try and doing search for those guys posts by Author. You will likely find a HUGE amount of information at your fingertips, far more than you probably need
. You could also have this moved over to the Handling section, those guys tend to stay there from what I have seen. I know from experience that F1fan responds favorably to PM's when asked (and when you have done a search or two). But you are going to need to be specific about what you want (i.e. what is the car doing now that you don't like and what are your goals? DD? 1/4 Mile? Road Course? SCCA Solo? You get the idea
Nice looking Black S197 BTW, like that Cervini's kit!
Good Luck
~Matt
simplexdesign,
).Nice looking Black S197 BTW, like that Cervini's kit!
Good Luck
~Matt
Lots of helpful info there Thanks. You knowits funny I just remembered there was a handling/suspension section lol
ORIGINAL: Fullsayl
No problem!
Out of curiosity, did you paint your calipers or is that an aftermarket kit in your sig?
Good Luck!
~Matt
No problem!
Good Luck!
~Matt
I went with Eibach springs and D-Spec struts and shocks. I lowered it and have Spohn LCAs and a one piece driveshaft. I have a Spohn adjustable UCA that I will be putting in very soon. I get a good ride.
ORIGINAL: SaddleUp
Simplex....
You gonna drop the front and the back??
I was thinking of dropping only the back......my front rides pretty low as it is.
Simplex....
ORIGINAL: Joolander
have you considered bullitt suspension?
the drop is only 1/8" in the back and none in the front
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
