Pulling to the right when mash on brakes?
#21
RE: Pulling to the right when mash on brakes?
project renegade.. thank you for the reply, (and everyone else).. i am going to check tire pressure today..
but project, i have a question for you.. if i go with new drilled/slotted rotors, and hawk pads all the way around or even just up front, will i notice a difference in braking overall?.. i have heard also that if you change the brake lines or fluid you can get a difference..
i hate these brakes, they are sooo mushy.. my brother in law's new 5.7 toyota tundra stops better than my car.. the brake on that thing are amazing.. barely press the thing and it stops on a dime.. how can i achieve this with out spending $2,000!?!??!
thanks
thanks
#23
ORIGINAL: Project Renegade
hi im a mechanic, and i see this all the time. its because of the latreral runout of your rotors. if you take the rotor off and look at it from the side, (depending on how severe it is) you might actually see that the rotor isnt perfectly parallel with it's other side, (which it should be) to correct this problem you need to either 1) get a whole brake job done (new rotors and pads) or 2) machine your rotors and get new pads. either way you deffinately need new pads.
glad to be of service
or with a dial indicator and a magnetic holder? Lateral runout sounds like they
are not true to the rotational axis, not different thicknesses around the rotor.
Please explain lateral runout once again for us dummies.
#24
Is your car lowered? If it is, was it realigned after lowering? Mine used to "bump steer" and pull a little to the left or right after lowering and mashing the brakes. I had it realigned Friday with almost 0 degress negative camber, and it seems the bump steering and pulling has gone away.
#25
ORIGINAL: rojizostang
The geometry of the tie rods and the steering rack have changed
from lowering and a Bump Steer Kit would be needed to eliminate
Bump Steer.
#26
ORIGINAL: 157db
Its kinda hard to get rid of Bump Steer by just an alignment alone.
Bump Steer.
Bump Steer.
