1st Dyno Run
1st Dyno Run
Finally got a dyno run on the GO. Little shop in Waukegan IL called Speedquest. Not a muscle car shop, but it is the nearest dyno. Let me know what you think.
http://i260.photobucket.com/albums/i...63/06May08.jpg
http://i260.photobucket.com/albums/i...ing05may08.jpg
RE: 1st Dyno Run
The pull was at STD conditions. Your dyno guy should have caught that.
The pull should have been under SAE conditions.
Corrected your doing about 10rwhp less than shown.
What really needs to be looked at is the A/F. The next time you do a pull have him put that on the graph also.
Even at 276rwhp thats not bad. Need to see the A/F's and at what rpm the engine is going into WOT.
As far as A/F's go, being N/A 12.8:1 to 13.2:1 is good. (I prefer 12.8:1)Then you can start messing around with the timing advance.
The next time you do a pull under SAE conditions, email or fax the pull to Brenspeed for review.
Galactic
04-29-2019 02:56 PM
